restrict door opening - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 24th, 2005, 07:51 PM
Local Time: 04:47 PM
Is there a way to restrict/reduce how far the passenger door will open on my 05 MCS? If I could only reduce the amount it opened by just a bit, it would keep it from wacking the other car in my garage.
Old Sep 24th, 2005, 09:08 PM
colink's Avatar
Bugaboo Racer
Local Time: 05:47 PM
Scotland Male View colink's Chili Red & White 1st Gen MINI Cooper S Profile
Try removing the other car from your garage Your MINI is entitled to every inch of space in your garage
Old Sep 24th, 2005, 10:52 PM
Quickbrick's Avatar
Local Time: 02:47 AM
Australia Male View Quickbrick's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
I was horrified to hear your MINI is in danger of being damaged in your own garage , so I started thinking of a solution like they used in the classic Minis. This is a strap made out of seat-belt material which mounts between the bottom of the A-Pillar and the door. You could shorten the strap to what ever length you wanted to create the correct door opening limit.
But of course you would have to drill holes in the MINI to do something like this, so this really isn't an option.
...so why don't you get the missus to sew-up a similar strap-like-arrangement which you can slip over your head and right arm to stop you from opening your door into the adjacent car
....Or just glue a big bit of foam rubber onto the adjacent car's door. I know it will look stupid, but this is the MINI we are talking about here rpgsat (unless the other car is a MINI too)
QuickBrick
Old Sep 25th, 2005, 08:17 AM
Paul's Avatar
MINI2 No.1
England Male
I find using my hand/wrist/arm I can open the door and manually control the amount it opens to avoid hitting any nearby vehicles. Worth a try?
Old Sep 25th, 2005, 08:51 AM
Roofas's Avatar
LBC SUCKS BUTT!!
United Kingdom Male View Roofas's Astro Black & Body Color 1st Gen MINI Cooper S Profile View Roofas's Classified Ads
lambo style doors - very expensive, very chav, but will do the job!
Old Sep 25th, 2005, 09:41 AM
colink's Avatar
Bugaboo Racer
.......unless you have a low roofed garage
I kinda like Paul's suggestion, particularly as it is portable to other situations, like car parks.
Old Sep 25th, 2005, 01:47 PM
Dr Phoo's Avatar
United Kingdom View Dr Phoo's Dark Silver & Black 2nd Gen MINI John Cooper Works Profile
There is a simple solution to this problem, one car goes in to the garage nose first and the other tail first.
To avoid any damage to the car doors attach a wooden bump board to both garage walls with a piece of felt stuck to the boards at the point where either door contacts the board.
This is a solution I use myself for my Cooper S and other BMW product!
Old Sep 25th, 2005, 10:40 PM
daisygirl's Avatar
Australia View daisygirl's Black-Eye Purple & White 1st Gen MINI Cooper S Profile
Build a bigger garage so there is more room between the cars.
Or get a different car (for the second one). Our Landcruiser 4wd you can open the doors and it is so high that they go over the top of the MINI and miss altogether.
The MINI is so much lower that when you open the door it goes under the 'cruiser and misses too !!!
Old Sep 25th, 2005, 11:14 PM
MINI-Morgan's Avatar
MINI Obsessed...
I like your style
Build a new level onto the garage and make a multistory...
Brief whirring noise when opening door McQz First Generation Interior & Ice 5 Apr 17th, 2006 02:28 PM
Opening door problem AZLAURA9 First Generation Faults & Fixes 3 Mar 2nd, 2006 12:43 AM
Auto window down when opening the door... Muel First Generation Faults & Fixes 1 Nov 22nd, 2005 08:09 AM
Freaky speedo vibe on opening the door? :/ basskiwi First Generation Faults & Fixes 5 Apr 21st, 2004 10:54 PM
Door Opening brycem First Generation Faults & Fixes 3 Dec 22nd, 2002 04:52 AM
