Aero side skirt - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 22nd, 2005, 12:01 PM
GTT 280's Avatar
The Power Cube
Local Time: 05:48 PM
United Kingdom View GTT 280's Classified Ads
DIY Aero side skirt
Hi,
Just had the side skirts fitted.
they don't appear to fit perfectly with the bodywork - the part near the door sill at the bottom right where it is ridged. the actual sill now also pulls fully away from the bodywork - i see that underneath there is ony sticky back plastic keeping it held on, are there no clips ????
i can provide photos if required....
Old Oct 22nd, 2005, 12:05 PM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
Your not the first, is it worse on the passenger side than the drivers side?
There are different coloured clips, some which are slightly longer than the others, if the wrong ones are used then it will sit slightly away from the body.
There are a few threads about it on MINI2, if you have a search I am sure you will find the answer
Old Oct 22nd, 2005, 12:14 PM
Rakey's Avatar
http://www.mini2.com/forum/showthrea...light=aero+gap
no answer in that one but it shows your not the first
but this next one explains how to solve it
http://www.mini2.com/forum/showthrea...ight=skirt+gap
Old Oct 22nd, 2005, 03:39 PM
fs-mini's Avatar
Local Time: 09:48 AM
United States View fs-mini's Pepper White & Black 1st Gen MINI Cooper S Profile
Yes, please provide photo. I just fitted mine the day before, I don't find any problem, or mis-fitted. May be I overlooked, but your photo may help to understand.
If there was a gap, would that be due you may still have an old clip still on the body, so the new one cannot be fitted in and created a gap? Just guessing.
MCS 05' - Delivered 09/23/04
Aero Side Skirt Supplier... Nick01329 First Generation MINI Exterior 1 Sep 29th, 2006 10:36 AM
Aero side skirt bits Richard82 First Generation MINI Exterior 2 Sep 25th, 2006 06:12 PM
Pics of Aero Side Skirt Only kooper trooper First Generation MINI Exterior 8 Jun 18th, 2004 03:24 PM
Aero Side Skirt Grills Cooperchris First Generation MINI Exterior 4 Jun 18th, 2004 11:36 AM
