Fitting Clear Rear Lights - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 27th, 2005, 10:04 AM
ronburgundy1234's Avatar
Proud Mini Owner
Local Time: 04:48 PM
United Kingdom View ronburgundy1234's Classified Ads
Woohoo purchased my black MCS last night, absolutely awesome.
I have just purchased some 2 rear clear lights and the third spoiler brake light to put on this and was wondering how easy/hard this is to do yourself?
Thanks,
Chris
Old Oct 27th, 2005, 05:08 PM
induct's Avatar
Do you mean the full clear rear lights or just the clear indicator. Also which phase of MCS is it 1st or 2nd?
I didn't think you could get a clear high level brake light?
Old Oct 27th, 2005, 06:57 PM
Proud Mini Owner
its a 03 reg MCS, its the full clear lights.
The third clear light is practically in the spoiler.
Old Oct 27th, 2005, 08:12 PM
tnoy66's Avatar
POP..POPPOP..POP
Online
Local Time: 05:48 PM
England Male View tnoy66's Pepper White & Black 1st Gen MINI Cooper S Profile View tnoy66's Classified Ads
The main lights are simple, remove the side covers in the boot, disconnect the lights, undo the 10mm nut, remove light unit, refit is reverse of that. Just don't overtighten the nut.
Top brake light is 4 torx screws, light pops out, disconnect wiring plug (that can be the hardest part sometimes, so mind the paintwork) refit in reverse order.
Then post pics once complete
Old Oct 28th, 2005, 09:43 AM
Proud Mini Owner
Thanks very much for the reply tnoy66,very helpful!
I'll post the pics once fitted.
Old Oct 30th, 2005, 08:15 AM
fone's Avatar
Yes, don't over tighten screws on the third top barke light.
Mine was fitted by dealer from new and after sometimes the lens developed a crack diagonally across it followed by numerous fine hair line cracks from the bottom edge. Remember this light takes alot of stress from the tailgate slamming down. Fortunately, I got it changed under warranty as it was an option taken when first purchased.
Old Nov 7th, 2005, 02:47 PM
Im lovin it
glad to hear it Chris
Black 03 MCS here too with the clear rears and upper brake light! you'll love it
wicked
Fitting clear rear lights Help ! Adam81 First Generation MINI Convertible 6 Feb 6th, 2007 07:29 AM
Help !!! fitting clear rear lights Adam81 First Generation MINI Exterior 24 Dec 14th, 2005 05:55 AM
Best rear reflector solution for clear rear lights garther First Generation MINI Exterior 4 Aug 19th, 2003 09:23 PM
