| | LinkBack | Thread Tools | Rating: |
| Sounds like you're the first to have this problem. I would take it to my local dealer to have looked at. I suspect there is a way to push it out from under the bonnet. If you open your bonnet, you can see the motor and assembly right beside the headlights. But because I have fidgety fingers that either get cut or I break something, I think I would get my local MINI mechanic to fix it. Hence if he screws it up, he can put a new one in at his cost. Be experience, if your car is under warranty still, your MINI mechanic will probably just put a whole new assembly in. |
| Don't know if it'll be of any use at all but have a look here: http://www.tepidcola.com/mini/Xenons%20&%20Washers.PDF MM |
| blocked rear washer | Haggi | First Generation Faults & Fixes | 11 | Jan 16th, 2006 03:35 PM |
| Do your washer jets get blocked easily? | Mega Mini | First Generation Faults & Fixes | 13 | Sep 26th, 2004 10:19 AM |
| headlamp washer hell ! | randolph03 | First Generation MINI Exterior | 18 | Jun 16th, 2004 12:33 PM |
| Headlamp Bottle washer Pointless Question | ALD0 | General Discussion | 4 | Mar 13th, 2004 05:53 PM |
| What's the headlamp washer frequency? | waynef | First Generation Faults & Fixes | 24 | Oct 8th, 2003 09:49 PM |
