Aero Kit and Lowering... - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 15th, 2006, 11:59 PM
MarkW19's Avatar
Grinning
Local Time: 05:51 PM
United Kingdom Male View MarkW19's Astro Black & Body Color 1st Gen MINI Cooper S Profile View MarkW19's Classified Ads
Just wondering, I'm getting Eibach ProStreet Coilovers for my Cooper in the summer, set on the 50mm lowering setting.
I'm also considering getting the Aero front and rear bumpers - I've heard the Eibachs on their own are pretty much ok for ground clearance most of the time (car parks, driveways, bumps, speedbumps etc.), but what about the Aero kit AND the Eibachs together?
Am I asking for trouble?
Old Feb 16th, 2006, 12:18 AM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
You'll find the splitter under the front bumper will scrape over bumps and up ramps. It does on mine lowered 30mm.
It was acceptable in the 80's
Old Feb 16th, 2006, 12:21 AM
MarkW19's Avatar
Grinning
Is it a big problem though, or just slightly annoying? Can it be modified or filed at all so it doesn't do it?
Baring in mind mine will be lowered 50mm!!
Old Feb 16th, 2006, 12:28 AM
wils's Avatar
formerly known as wsw
Local Time: 02:51 AM
Hong Kong Male View wils's Chili Red & White 1st Gen MINI Cooper Profile
i don't have an aero kit, but normal eibachs and lowering 30mm and the bottom of the normal bumper is in pretty bad nick....50mm and an expensive aero kit i reckon it'll look awesome but ur definatey asking for trouble.....
i got an exhaust because i wanted to make my car sound fast, but its not fast at all, so therefore i am a ricer....
Old Feb 16th, 2006, 12:30 AM
MarkW19's Avatar
Grinning
I've got normal Eibachs now too (30mm lowering springs) and I don't scrape much at all - just if I go too fast up a ramp or driveway etc. Speedbumps are usually fine.
But as you say with the extra drop to 50mm AND the Aerokit.........
Old Feb 16th, 2006, 12:39 AM
monkeynuts's Avatar
my ponies have escaped!!!
England Male View monkeynuts's Classified Ads
im on KW -35mm with aero kit and only scrape now n then but im on 18" rims
really depends on size rims doesnt it?
i cant at all park half on half off a kerb unless its flat and therefore not a kerb
if it dont scrape it aint low enough.....as they say
m o n k e y : n u t s
Old Feb 16th, 2006, 12:41 AM
MarkW19's Avatar
Grinning
Hehe...
I've got 17" S-Spokes, with Toyo T1S 215/40 tyres. Lowering by 50mm.
What do you mean you can't park half on half off a kerb - you mean you can't have one wheel on the kerb and one wheel on the road (so the car's slanting)? I don't see why you can't do this??
Old Feb 16th, 2006, 12:42 AM
Not a big problem no. If you go over bumps slow it's ok. Normally if you've got a bit of momentum it must compress the suspension enough to scrape. I have to put one wheel up over the cushion bumps or I will get a guaranteed scrape.
I must say though my splitter is in a bad way. Even the dealers said it's pretty bad under there. I think it does affect aerodynamics so probably not a good idea to go cutting it either.
Old Feb 16th, 2006, 12:45 AM
MarkW19's Avatar
Grinning
How do you mean?
Old Feb 16th, 2006, 12:49 AM
monkeynuts's Avatar
If i park half on half off ie at a slant im wrecking the front lower lip which is attached to the bumper therefore wrecking that too
Old Feb 16th, 2006, 12:50 AM
MarkW19's Avatar
Grinning
You mean because the middle of the lower lip is in contact with the edge of the kerb?
Old Feb 16th, 2006, 12:51 AM
monkeynuts's Avatar
yup in most situations yea, which at times can be an asss
Old Feb 16th, 2006, 12:52 AM
MarkW19's Avatar
Grinning
With me having 17" wheels as opposed to your 18's, I'll be a bit higher won't I?
MarkW19's Avatar
Grinning
Obviously with the extra 15mm I'll be dropping mine, we should be riding at about exactly the same height?
  #15 (permalink)
Old Feb 16th, 2006, 12:55 AM
monkeynuts's Avatar
not sure as the walls on your 17" should be thicker ie the profile (i think)
im not a tyre guru but with 18"s imo you have to have lower profile to fit under arches as far as im aware but i think s-spokes on runflats are same if not slightly bigger than 18's with low profile tyres
i think
Eibach Lowering Kit minilka First Generation MINI Suspension 3 Apr 25th, 2005 09:32 PM
The BEST lowering kit for MINI Cooper S! heo1977 First Generation MINI Suspension 19 Jul 19th, 2004 04:08 PM
aero kit plate holder on non aero kit bumper ChilliSteve First Generation MINI Exterior 4 Apr 13th, 2004 10:59 PM
Lowering and camber kit nparker First Generation MINI Cooper S 1 Apr 17th, 2003 08:18 AM
Lowering kit with 18's? Bobcruchett First Generation MINI Suspension 9 Oct 25th, 2002 04:16 AM
