Retro Fitting Fog Lights to 2002 MCS Help needed - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 19th, 2006, 05:06 PM
zanhar25's Avatar
zanhar25
Local Time: 05:51 PM
England Retro Fitting Fog Lights to 2002 MCS Help needed
For Christmas my good wife bought me a genuine BMW Mini retrofit foglamp kit (Part No: 63 17 0 300 329)
It also came with instructions for fitting (title Fog Light retrofit Kit Mini R50)
Instructions state that fitting should take 2 hours depending on condition of vehicle. There was nothing wrong with my car and it took me 6 hours to fit fog lamps,fitting and terminating cables under the bonnet and getting the last 4 cables into the cabin.That was Early January,Today I thought I'd finish of the job as I was fed up with keep driving about with the glove box out and the fog lamp cables coiled up
firstly the instructions cable run didn't seem right so I ran them with the main loom under the dash top,al seems O.K but the 2 module cables now seem too short No problem if need be I'll extend them .Secondly the terminal s 7 & 3 on the switch panel 18 pin plug that these two cables go to already have cables fitted (Yellow /Broiwn in pin 7 & Red / Grey in pin 3) .I never even bothered trying to connect into the control moduleSo another 2 hours and I still have no working fog lamps,but my interior is back together .
By the time they are finished it will be summer
So this is where I need help.I've come to the conclusion that these instructions only refer to the Cooper (R50)and not apply to MCS (R53)( I've seached the web and only found the same instructions I already have!!!!.I'll paste a link once I've posted this) This may also explain that the relay and fuse that came in the kit and was meant to be fitted under the bvonnet in the fuse box was already fitted
So does anybody have any fitting instructions for a MCS?Or can tell me where the final 4connectins go.or that all the wiring under the bonnet was correct.
Any help would be greatfully received.
Any body going on the London To Brighton this year?
Regards Zanhar 25
Old Feb 19th, 2006, 05:09 PM
zanhar25's Avatar
zanhar25
Retro fog lamp problem
Here's the instructions that I found on the web
http://www.motoringfile.com/howto/Fog%20Lights.PDF
Old Feb 19th, 2006, 05:32 PM
MINIAC's Avatar
Canned
Local Time: 09:51 AM
The retrofit kit number you have doesn't match any of those listed in the PDF.
Old Feb 19th, 2006, 06:36 PM
dannit's Avatar
Checkers Everywhere!!!!!!
Send a message via AIM to dannit Send a message via MSN to dannit
Local Time: 04:51 PM
United Kingdom Female View dannit's Cosmos Black & White 1st Gen MINI Cooper Profile
i had the same problem!!!!! then after 8 hours found out that they have to be turned on by BMW anyway, i was quoted £30 for a min hours work, apparently it takes about 3mins for them to plug in a comp and switch it on!
Old Feb 19th, 2006, 07:01 PM
mini tech
Send a message via MSN to stevesace
England
they need coding into the BC1 via DIS by a bmw dealer.
Old Feb 19th, 2006, 07:08 PM
rkw
United States View rkw's Pepper White & Black 1st Gen MINI Cooper Convertible Profile
zanhar25, there is an error in the original fog retrofit instructions (the one posted on MotoringFile). Where it says to connect pins 7 and 3 for the toggle panel, should have read 17 and 13. You'll see the correct pins listed if you look at the connection diagram in the instructions.
I have an updated set of instructions (the one on MotoringFile is dated 2001!). You can down load it here: http://briefcase.yahoo.com/bc/rkwoo@...lst?.dir=/MINI. The instructions are really the same but the error has been corrected. My retrofit is half done (not yet routed into the cabin) and I was fortunate to see that someone had posted about the error on northamericanmotoring.com.
Old Feb 19th, 2006, 09:01 PM
zanhar25's Avatar
zanhar25
Fog light retrofit.
I noticed that when I got them but that ,but that was what my dealer gave me when I picked the kit up so I assumed it was the same procedure for all models/ retro kits,
Old Feb 22nd, 2006, 05:24 PM
wils's Avatar
formerly known as wsw
Local Time: 02:51 AM
Hong Kong Male View wils's Chili Red & White 1st Gen MINI Cooper Profile
i have always wanted to get a retrofit kit for foglights, would u mind me asking how much it cost? is it extremely difficult to do?? not worth AUD$700 (approx 300GDP) though? (that's how much bmw quoted me to fit them)
i got an exhaust because i wanted to make my car sound fast, but its not fast at all, so therefore i am a ricer....
Old Feb 22nd, 2006, 06:21 PM
zanhar25's Avatar
zanhar25
England
Ther cost £115 GBP and not to difficult to do now I now the shortfalls
Old Feb 22nd, 2006, 08:42 PM
zanhar25's Avatar
zanhar25
England Retro fitting Fog Lamp Kit
Thanks for that information,I'm a bit peeved to know that I'll have to have them activated at a dealer when my original instructions stated different
Has anybody else thought the loom is a bit on the short side if routed with original loom under dash top??
Fitting fog lights IH1 First Generation MINI Exterior 3 Jul 10th, 2006 08:03 PM
Retro-fitting New Shape Xenon Lights. harrop First Generation MINI Exterior 48 Feb 22nd, 2006 05:40 PM
Fitting fog lights....easy? Veron781 First Generation MINI Exterior 7 Oct 11th, 2004 03:07 AM
Fitting Fog Lights - is it hard to do ? DCM First Generation MINI Exterior 3 Aug 11th, 2004 11:47 AM
Fitting Fog Lights theminiv First Generation MINI Exterior 6 Apr 17th, 2004 05:28 PM
