| Is there any kind of guideline on this? I mean, I'd be happy to put them on, and removed them after 18 months, 2 years or whatever if that's a "safe" time period? It would even be worth it to apply, removed clean, apply, every 12 months if that meant avoiding long term paint defects. |
| As many of you probably know red is the color most sensitive to fading. This is because the red light hold the most energy (hence the fact that infrared is red). When light hits a red car, the red light is absorbed by the paint so you see the car as red. So red paints is the color that absorbs the most energy. Energy causes paint discoloration because the energy breaks paint molecules and paint stabilizers down, so red is the color that fades first. So the fact that this doesn't occur on a BRG in 18-24 months does not mean it will not happen on a Chili Red MINI in that period of time. Shielding you MINI from direct sunlight will increase the lifespan of the paint very much. I have applied a teflon layer called ProTech on mine. They claim the paint will only deteriorate a few percent per year instead of 20, but only time will tell. My 3 year old EB/MCS still shines like new though (and thats measured with a gloss meter). It's not a certainty but applying such a layer (and parking it in the shade) would give the best protection against paint discoloration in my opinion. Maybe you could shield a part of the car with some kind of small decal that is easily removed and applied again, and check for fading under the small decal. It should be on a flat surface like the bonnet or roof because these fade first. As soon as you can see the slightest color fading you should take of all the decals. BTW, it looks great! |
| Modern paints are not as prone to fade as on older vehicles, and MINI only use the best quality materials I'm sure. 3 to 4 years will be fine, but since when have you kept a car that long. Anyway, you'll probably re-vamp the graphics when you redevelop the site for the MK2, Will there be a NewMINIMINI2.com ![]() newminimini2.co.uk Available newminimini2.org.uk Available newminimini2.me.uk Available newminimini2.com Available newminimini2.org Available newminimini2.net Available newminimini2.info Available newminimini2.biz Available newminimini2.tv Available newminimini2.ltd.uk Available newminimini2.plc.uk Available newmini.co.uk Taken newmini.org.uk Available newmini.me.uk Available newmini.com Taken newmini.org Taken newmini.net Taken newmini.info Taken newmini.biz Available newmini.tv Available newmini.ltd.uk Available newmini.plc.uk Available |
| I agree with all posters above, Red fades, but MINI uses good paint. What makes you think the new owner would not like the stripes? That does not appear extreme. But, I am not English. Our New Beetle with Daisy wheels went for a premium to a buyer halfway across the country because the new owner took a fancy to the look of the car with those wheels. ![]() |
| I think so long as you protect and look after your paint work, in the short term (1 - 2 years) you should be fine. The same thought crossed my mind when I was thinking of getting graphics on my Works. |
| Have to reply to this. Back to some basic physics. Here is an example: If white light (ordinary sunlight, for example) passes through copper(II) sulphate solution, some wavelengths in the light are absorbed by the solution. Copper(II) ions in solution absorb light in the red region of the spectrum. The light which passes through the solution and out the other side will have all the colours in it except for the red. We see this mixture of wavelengths as pale blue (cyan). So this means that if you see a red car it absorbs all other colours except red (complementary colour) Sorry Paul, I know this is not related to your question. IMHO if you would leave your car on a direct sun light during summer time (longer period) it could result in a slight fading. |
| Providing your keep the car polished and waxed there is no reason why the paint should fade for many years. Yes red is the most prone colour to fade but not if it's looked after properly. You see many 80's cars where the paint has faded due to improper care. Then again think of cars like the XR2i, RS Turbo I've seen many of them with gleaming paint work where they've been properly cared for and that is on cars that have not been resprayed. ![]() It was acceptable in the 80's |
| Bonnet stripe - paint fade | yoni99 | First Generation MINI Exterior | 7 | May 17th, 2006 12:06 PM |
| Factory stripes. Are they paint or decals? | oo7indenver | First Generation MINI Exterior | 5 | Jan 13th, 2006 06:05 PM |
| Does the paint fade? | AMUSE COOPER S | First Generation MINI Exterior | 9 | Aug 28th, 2004 04:35 PM |
| HK fade control | kcmcs | First Generation Interior & Ice | 3 | Apr 29th, 2004 12:02 AM |
| Red, will it fade? | Martin L | General Discussion | 19 | May 29th, 2003 11:22 AM |
