colour coding arches your self - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 23rd, 2006, 06:33 PM
Send a message via MSN to newbz
Local Time: 04:52 PM
hi, im planning on colour coding my arches my self, any one got any tips, like should i take them off or leave them on, if i should take them off how do you take them of, n the right paint n primer n sand paper to use n all that kind of stuff, cheers for any help
Old Mar 23rd, 2006, 06:40 PM
Gr8Dain's Avatar
Gotta Get Out More!!!
Local Time: 12:52 PM
United States Male View Gr8Dain's British Racing Green & Black 1st Gen MINI Cooper S Convertible Profile
I can't help with all of your questions, but I would definitely take them off. It will be easier to sand the arches smooth and paint without having to worry about the body of the car.
Take your time and make sure the parts are really prepped. You will undoubtedly need to add a flex agent to the paint to make sure that it does not simply crack and flake off immediately. Or even when refitting. I have read that the arches are only held on by a couple of screws then snapped in most places. You should be able to search and get that answer. Sorry, but I have not done it, so I am not sure.
Good luck.
Old Mar 24th, 2006, 02:44 AM
notts04chillimini's Avatar
hey lightbulb head....
Send a message via MSN to notts04chillimini
Local Time: 05:52 PM
England View notts04chillimini's Chili Red & White 1st Gen MINI Cooper Profile
England
i wouldnt recommend doing them yourself as the paint will need to be mixed by a proffessional to get the right colour match to your car, you wont be able to get a correct match just by the code,
they will need to be taken off the car and sanded with wet and dry paper many times over to get a good smooth finish and different grades will need to be used to get a good key, they then will need to be primered a few times with special hardeners aswell... then flatted back with wet and dry again to leave a good key for the paint...
in my opinion you wont get a good finish without taking it to a body shop
Old Mar 24th, 2006, 02:55 AM
MiniFr34k's Avatar
fr34king n00b!
Local Time: 02:52 AM
Australia Male View MiniFr34k's Classified Ads
Hi
Not sure about DIY - but ive spoken to a few panel beaters about the process they would use for painting the arches before choosing one that did mine.
This is what they told me
1) take off all the pieces - real pain in the ..... because theres all these clips - some broke off and they had to buy new ones to replace the old
2) Sand down the plastic to get it smooth
3) Prime x 2 layers, rubbing down each layer to get it smooth again
4) Paint.
Im positive i either skipped a step or something was left out but i think thats the jist of it - however i've come to learn that all DIY projects (big or small) are never simple as that.
Cheers & good luck.
Old Mar 24th, 2006, 05:40 AM
n00b's Avatar
Twincharge???
Australia View n00b's Classified Ads
You're better off replacing all the clips - they really only meant to have a service life upto the point you take them off...
Someone over on NAM commented you might be better off starting with a fresh set of archers/trims if you have waxed it as getting rid of that is pretty hard or as they say. You could cut a bit of cost of getting someone to paint these by removing and fitting them yourself along with rubbing it down...and you may need to speak to the person who's painting them as to how they would like you to rub it down to smooth it.
Old Mar 28th, 2006, 09:34 PM
any one know how you get them of, any guides about and is there any where can buy a set of them for the aero kit to try n paint so if i mess it up still got my old ones ?
Colour Coding - Wheel Arches w/ Aero Kit mab First Generation MINI Exterior 4 Jul 2nd, 2007 07:46 PM
colour coding arches ..lee1.. First Generation MINI Exterior 0 May 4th, 2005 05:20 PM
Colour coding wheel arches - Swindon area smithej First Generation MINI Exterior 2 Mar 30th, 2005 07:30 PM
Bodyshop recommedation in northants/bucks/beds for colour coding arches MINI115 First Generation MINI Exterior 0 Mar 28th, 2005 08:27 PM
Colour coding wheel arches - NEED HELP! Adeline First Generation MINI Exterior 5 Jul 1st, 2004 08:33 AM
