Headlights cover - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 14th, 2006, 12:25 PM
Richard22b's Avatar
MINI Mad
Send a message via MSN to Richard22b
Local Time: 08:12 PM
United Kingdom Male View Richard22b's Classified Ads
Headlights cover
I have got new silver surround for my headlights but am unsure how to get the old ones off to put the new ones on.
anyone done this or know how.
Old May 14th, 2006, 01:40 PM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
do you have standard lights or xenons?
perhaps some of the drawings on here might help you figure out how it all comes apart
www.realoem.com
Old May 15th, 2006, 11:51 AM
Richard22b's Avatar
MINI Mad
Had a look but it doesn't quite show in detail enough. I need to know if it is just glued on or screwed. someone out there must know
pleaseseseseseseseseasesasesaseesasesaaeesaase
Old May 15th, 2006, 08:24 PM
Pobsey's Avatar
The de Chromed MINI
Send a message via MSN to Pobsey Send a message via Yahoo to Pobsey
Local Time: 07:12 PM
United Kingdom Male View Pobsey's Dark Silver & White 1st Gen MINI Cooper S Profile View Pobsey's Classified Ads
the chrome rings are held on with a combination of clips and a sticky pad, You need to work the bottom of the ring loose first as the clips at the top are bigger, You WILL need to take the headlight out of the bonnet to do it,
Hope this helps
Headlights Raul First Generation MINI Exterior 0 Oct 6th, 2007 12:55 AM
Headlights and AC of GP MIN 18 First Generation Works 5 Feb 5th, 2007 09:44 PM
New headlights LookalikeJCW First Generation MINI Exterior 4 Dec 22nd, 2006 05:49 PM
Headlights Bayliner First Generation MINI Exterior 8 Sep 2nd, 2006 07:51 PM
Headlights go on by themselves??? hjacobs475 First Generation Faults & Fixes 6 Nov 5th, 2004 01:53 PM
