Xenon Headlights - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 18th, 2006, 10:30 PM
Local Time: 09:53 AM
Green Cooper Xenon Headlights
how can i tell if i have Xenon headlights or just the other regular headlights??
The Dealer said to look for a yellow sticker and it should say on there but i dont see a yellow sticker on the headlights...
Old May 18th, 2006, 10:35 PM
Electric Blue's Avatar
Local Time: 04:53 PM
look at the headlight, inside woill say Xenon. are they VERY clear and do they "flicker" into life when turned on? if they do, good chance they are xenons
Mini_Anton's Avatar
It's a Mini Adventure....
Send a message via MSN to Mini_Anton
Local Time: 05:53 PM
United Kingdom Male View Mini_Anton's Pure Silver & Black 1st Gen MINI Cooper Profile
I thought the colour of the lights might be the main give away! Xenons tend to havd a bluish/white light to them.
On facelift Mini's you can just look at the headlight to see if you have Xenons.
Old May 18th, 2006, 10:39 PM
Ingrid's Avatar
Go kart
Send a message via MSN to Ingrid
Local Time: 06:53 PM
Norway Female
Facelift xenons:
Pre-facelift xenons:
Non xenon:
Old May 19th, 2006, 06:41 AM
KPKalle's Avatar
50 PMs no sig group
England Male View KPKalle's Laser Blue & White 2nd Gen MINI Cooper S Profile
Bright white light = xenon
Old May 19th, 2006, 06:51 AM
MiniFr34k's Avatar
fr34king n00b!
Local Time: 02:53 AM
Australia Male View MiniFr34k's Classified Ads
xenons also have the headlight washers....
Old May 19th, 2006, 07:11 AM
fone's Avatar
The older ones have a more yellowish light rather white light - according to my dealer.
Old May 19th, 2006, 08:17 AM
BlueZed's Avatar
Staying shiny-side up!
Ireland Male
You can also look at the headlight lens, if it has H7 inscribed on it then you have Halogen not Xenon.
You can get a Xenon look by replacing the bulbs with something like the Phillips Power-Blue bulbs e.g. from Powerbulbs.com. Had them in my old car and the light they gave off was much nicer than the standard Halogen, fairly white with a slight blue tinge, but not to bright blue chav levels!
What new bits? I didn't buy any new bits...
Old May 19th, 2006, 06:07 PM
monkeynuts's Avatar
my ponies have escaped!!!
England Male View monkeynuts's Classified Ads
if you look close too it actually says Xenon on the the smaller cirlcular plastic thing inside the headlamp ....BIG CLUE
m o n k e y : n u t s
Old May 19th, 2006, 06:09 PM
SiBradbury's Avatar
United Kingdom Male View SiBradbury's Classified Ads
Yep, cars with Xenons have to have headlight washers apparently.
No headlight washers, no xenons!
Old May 19th, 2006, 06:34 PM
United Kingdom Male View S33BBY's Hyper Blue & Black 1st Gen MINI Cooper Profile View S33BBY's Classified Ads
I think you can get halogens with washers, but don't let me confuse matters...
Old May 19th, 2006, 07:02 PM
envy's Avatar
Now im Hyper!
United Kingdom View envy's Classified Ads
Hmm i have an 06 mini and really think i should have had the Xenons.
Now its delivered and too late
Could i install the new facelift Xenons myself? If so any ideas on what 2 do?
If not i think i saw a BMW place that could install them for £500.00
I know that BMW wanted about £1200 to install them.
Old May 19th, 2006, 07:05 PM
fone's Avatar
You should look for these bits (for older model) behind the light
http://www.realoem.com/bmw/showparts...=63&fg=05&hl=9
http://www.realoem.com/bmw/showparts...23&hg=63&fg=05
and a high voltage warning sticker
Old May 19th, 2006, 07:06 PM
nylo's Avatar
Totally Mental!
Northern Ireland Female View nylo's Space Blue & Silver 1st Gen MINI Cooper S Profile View nylo's Classified Ads
This topic has been covered before, try this link:
http://www.mini2.com/forum/exterior/...ight=06+xenons
Hope that helps
  #15 (permalink)
Old May 19th, 2006, 07:07 PM
The short answer is yes. The long answer is no. If you were to buy the xenon units, these are pretty much plug and play. The problem is that to meet legal requirements, they must be connected to suspension sensors so they can automatically level, as well as be connected to the washer system. The washer part may be relatively easy, but the suspension part more difficult. I've certainly not read of anyone installing them completely; only simply swapping the actual units.
The place that will fit them for £500 will most likely only fit the xenon units. BMW most probably want to charge £1,200 as the labour will probably be quite high, not to mention the cost of the parts.
You could consider installing something like this instead:
http://www.powerbulbs.co.uk/product....For=&PT_ID=112
xenon headlights minime37 First Generation MINI Cooper S 31 May 3rd, 2009 04:32 PM
New Xenon Headlights johnnyv First Generation MINI Exterior 10 Nov 10th, 2008 05:21 PM
Non xenon headlights pardonator First Generation Faults & Fixes 2 Jul 21st, 2006 11:52 AM
xenon headlights help please cochito First Generation MINI Cooper S 11 Oct 25th, 2005 03:27 PM
Headlights Xenon! Gordonh First Generation Faults & Fixes 1 Sep 30th, 2005 05:41 AM
