Sill Plate help needed badly - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 2nd, 2006, 10:04 AM
Richard22b's Avatar
MINI Mad
Send a message via MSN to Richard22b
Local Time: 06:29 PM
United Kingdom Male View Richard22b's Classified Ads
Yellow Cooper Sill Plate help needed badly
Hi All
I need help.
The sill plates in my MINI of 4 years are starting to peal. There appears to be a plastic coating on them which is coming off.
Is this coating meant to be on there or should have been removed years ago.
I need to solve this today as tonight i will buy new ones at a price of £27
what do you think.
Old Jun 2nd, 2006, 10:16 AM
Simpa's Avatar
Send a message via MSN to Simpa
United Kingdom Male View Simpa's Chili Red & White 1st Gen MINI Cooper Profile
After putting a body-kit on my car i bought new sill plates which had a protective plastic on the top, so i would suggest peeling the plastic off to see what they look like.
Old Jun 2nd, 2006, 10:19 AM
red cooper1's Avatar
Local Time: 03:29 AM
Australia View red cooper1's Chili Red & White 1st Gen MINI Cooper Profile
protective coating
As far as i am aware the coating just gives a bit of protection. it will not hurt to remove it. If small scratches appear car polish will work ok.
Old Jun 2nd, 2006, 10:22 AM
Richard22b's Avatar
MINI Mad
I have peeled them off a bit and i think after a clean they will look ok. The bit with the plastic on does feel plasticy (surprisingly) and the other bit feels like metal.
But i do know that often metal parts have a plastic cover to stop corrosion.
Old Jun 2nd, 2006, 10:27 AM
Simpa's Avatar
If you were going to put new sills on the double sided tape they use is surprisingly strong, so if you take your old ones off be extremely careful!!
Old Jun 2nd, 2006, 11:02 AM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
The short answer is it should of been removed years ago. It's just the plastic protective layer they put on to stop the metal getting scratched in transit.
Had you removed it before you would have noticed that the finish is shinier with the plastic removed.
Take it off and use a decent metal polish to bring them up as good as new. I recommend Meguiars Metal Polysh (their spelling not mine). Available from most Halfrauds stores.
It was acceptable in the 80's
Removing Sill Plate Adhesive Residue hairyhen First Generation MINI Exterior 6 Jul 27th, 2004 12:09 PM
Cheeky license plate needed spyderphil General Discussion 9 Jun 4th, 2004 06:58 AM
pic needed of JCW sill plates on aerokit skirts Darren S First Generation MINI Exterior 7 Apr 21st, 2004 03:28 AM
Personalized License Plate - Advice Needed! dansmini General Discussion 11 Jan 25th, 2004 06:33 PM
Number Plate Opinion Needed! MINIALEX General Discussion 9 Jan 27th, 2003 12:16 PM
