| I'll try and explain it after recently installing them on the other halfs cooper. I assume first of all that the brackets are as below? I have labelled them as though you are looking from the front of the Mini. You slide each between the grilles and the furthest point left and right and marry them up to the bonnet bracing. You can then mark and drill (carefully) small guide holes. the ones I bought didn't come with nuts and bolts, so I used some self tappers to fix them. A great addition I think. ![]() Hope that helps. ![]() HANG ON, HANG ON, I got it wrong. Read left as right and right as left... D'oh! |
| DOH! I didnt see this bit "HANG ON, HANG ON, I got it wrong. Read left as right and right as left... D'oh!" fitted mine and thought "hmmmmm they look a bit far in", time to unbolt & unscrew ![]() |
| Looking for lamp brackets | dangerous1 | First Generation MINI Exterior | 0 | Jun 14th, 2005 03:17 PM |
| Driving Light brackets | chughes163 | General Discussion | 0 | Jan 26th, 2004 06:13 PM |
| Brackets !! | geist | First Generation MINI Exterior | 0 | Sep 23rd, 2002 01:52 PM |
