Removing Roof Decals I have a target on the roof of our MCS and would like to remove it. 1) How best do we do this? 2) If it has been on 3 years will it have marked the roof or will it be discoloured? 3) If discoloured, will it be easy enough to t-cut so it is not noticeable? Thanks in advance |
| hi use a degreaser from a motor factors (they use it to cleans grease off components) we do decals in work and are constantly stripping old decals the brand we use it in work and its called "Upol anti silicone degreaser" Make sure its not white spirit (do a test somewhere inconpicious)!! tell them its for a sprayed finish when you buy its powerful, you wont need much, 500mls would be plently if the goo is heavy, cover the area in tissue and soak the tissue with the degreaser and let it work for a few minutes if its drying out, wet it a bit more, it will wipe off easier that will definately work, but Im wondering whether a household window/glass spray would work may be worth a try regards four |
| Thanks Four Any thoughts on if it will leave marks behind where the decals were? Bearing in mind its not a full decal but a series of them placed on the roof ie some of the roof has not covered by decals for 2 years where as other bits have. Im thinking of waethering to the uncovered paint etc. |
| Roof decals and moon roof | Nimiety | First Generation Interior & Ice | 7 | Jun 25th, 2006 11:12 AM |
| Removing vinyl decals | hyperbluejames | First Generation MINI Exterior | 2 | May 28th, 2006 10:22 AM |
| Removing decals from One 7 | jamiebae | First Generation MINI One | 6 | Dec 1st, 2005 10:10 PM |
| Removing 05 Roof Aerial for roof decal fitting | Benfrain | First Generation MINI Exterior | 5 | Aug 27th, 2005 02:58 PM |
| Roof Decals | REAL MINI S | First Generation MINI Cooper S | 0 | Apr 29th, 2003 11:44 AM |
