Spotlights - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 30th, 2006, 05:07 PM
MarkW19's Avatar
Grinning
Local Time: 05:55 PM
United Kingdom Male View MarkW19's Astro Black & Body Color 1st Gen MINI Cooper S Profile View MarkW19's Classified Ads
Spotlights
I'm thinking of fitting 2 spotlights to the front of my car, but only if I put the aero grill back on there (currently debating!!).
But, I'd want the spots to act as the full beam, so just on when I flash and when fullbeam is on. However, I'd want them to be on on their own, for full effect...so I'd be wanting to take the fullbeam bulbs out of the main lights.
So my questions are:-
1. Is it legal to remove the fullbeam bulbs and just use the spots for this.
2. Will the spots be bright enough to replace the fullbeams for flashing?
Old Jul 30th, 2006, 07:08 PM
MarkW19's Avatar
Grinning
Am I right in thinking the standard BMW spotlights are set up to come on with the main (xenon) beams (automatically if you have auto headlights), and ALSO when you flash/put fullbeam on?
Old Jul 30th, 2006, 09:06 PM
minicore's Avatar
Super Moderator
United Kingdom Male View minicore's Chili Red & Body Color 2nd Gen MINI John Cooper Works Profile
AFAIK, by default the spots only come on with your full beam.
Old Jul 30th, 2006, 09:39 PM
MarkW19's Avatar
Grinning
Right
Old Jul 30th, 2006, 09:46 PM
Widgey's Avatar
United Kingdom Male View Widgey's Chili Red & Body Color 1st Gen MINI One Profile
"So my questions are:-
2. Will the spots be bright enough to replace the fullbeams for flashing?"
Answer:
1) No. Your headlamps must have bulbs (working) in them
2) Same wattage (about 55w, I think)
Whatabout "off-road" spec bulbs for the spots?
Far brighter than "normal" and you're only gonna use 'em occasionally aren't you?
Old Jul 30th, 2006, 09:49 PM
MarkW19's Avatar
Grinning
Thanks Widgey...
The main reason I don't want the spots on with the main lights is because they won't match the colour of the Xenons...and also I'd like the novelty of a "flash" just coming from the spotlights only.
Looks like my only choice is to have the spots on with the fullbeams at the same time then, legall (and insurance-wise)
Old Jul 31st, 2006, 05:30 AM
Baker's Avatar
Being normal is not fun!
Local Time: 03:55 AM
Australia Male View Baker's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Flash is better with nice bright globes in both headlight cluster and spotties.
Also, change the headlight high beam bulb so that its a bit brighter
Spotties won't be on unless your main beam is on, which won't be that often, so who cares if it matches Xenon or not, as if anyone would be seeing it from the front you'd turn them off anyway .
Old Jul 31st, 2006, 02:23 PM
United Kingdom View Tonic_Neil's Classified Ads
On the same subject, I recently purchased 2 spots and brackets along with a wiring kit off of eBay.
The instructions, I think trying to remember, say to tap into a Yellow and blue cable on the drivers side headlamp, but I can't locate that. There is a Yellow and Green (I think. It was a couple of weeks ago when I took a look and gave up).
Anyone done this before? They're not the official BMW version that need activating.
Neil
Old Jul 31st, 2006, 04:30 PM
United Kingdom View den123's Classified Ads
England colours
hi guys what colour wires do the spot lights have to be wired to thanks none bmw spots
4 spotlights garyb1 First Generation MINI Exterior 10 Oct 31st, 2006 06:51 PM
4 Spotlights john boy First Generation MINI Convertible 2 Aug 30th, 2006 10:44 PM
Spotlights (AM) BDL First Generation MINI Exterior 3 Aug 12th, 2006 07:30 AM
spotlights den123 First Generation MINI Exterior 0 Jul 2nd, 2006 02:10 PM
