Wipac Spotlights wiring.. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 10th, 2006, 09:07 PM
ScottyBoy's Avatar
Obsessive Car Cleaner OCC
Local Time: 05:57 PM
United-Kingdom Wipac Spotlights wiring..
Hi all,
im soon going to be fitting a pair of wipac 5" spots and wondering if theres any instructions on hear of DIY fitting that i can read...? if someone can post me a link that would be great!
also does anyone no when these lights are legally aloud to be used so i dont get pulled over
Cheers!
Old Aug 11th, 2006, 03:00 PM
Richard82's Avatar
Toot toot, honk honk!!
Local Time: 04:57 PM
United Kingdom Male View Richard82's Hyper Blue & White 1st Gen MINI Cooper S Profile View Richard82's Classified Ads
They are allowed to be used legally but only as part of the full beams. i.e you can't wire them in to come on with your dipped headlights as this would be an illegal use.
Have you got all the wires etc with your Wipacs? where did you get them as im after a set to put on my car
Old Aug 11th, 2006, 04:56 PM
ScottyBoy's Avatar
Ye ive got the wires i bought them with a set 5 1/2" lights of ebay then relised i wanted the 5" spots so i sold the bigger 1's and bought another set of 5" spots with brackets of ebay and kept the wiring!
the wiring has its own switch but i dnt think im gunna be cutting a hole anywere for it!!
Old Dec 24th, 2006, 09:54 AM
anyone no where i can purchase the spot light wiring loom?
thanks
Old Dec 24th, 2006, 11:27 AM
ScottyBoy's Avatar
The wiring loom i got is just plain black wire thats all you need really one long lenght so you can cut it upor maybe go to a place likemotorworld or halfrauds etc! then with that you will need an inline fuse and relay! i can make a set of instructions for you if needed!
scott
Old Dec 24th, 2006, 11:44 AM
Don't worry about the wiring loom....its just a few bits of wire. The inline fuse is one bit you need....the relay is the other bit, you can buy all the parts you need individually from Halfords. Its nothing extravigant at all just normal wire.
Theres no mystery in doing the lights at all, as Scott above will tell you.....I was a bit aprehensive and needant have been .
It's gotta be yella'
Old Dec 24th, 2006, 02:15 PM
i have actually got a wiring loom its off a mini with relay but someone said it goes to ecu then has to be prog by bmw to work? is there anyway of modding this wireing loom to just connect to the high beam wire?
Old Dec 24th, 2006, 02:24 PM
i no the wires that go to the spots there the brown and red, i got a red and white wire with ring connector on then a bunch of brown wires with ring connector on, and a short brown and white wire coming out the relay?
Old Dec 24th, 2006, 11:51 PM
Hi there do spots need to be coded an if so how or who can do it ?
I am new to all this hope someone can help.
Old Dec 25th, 2006, 12:47 AM
United Kingdom View straff2002's Classified Ads
I just installed a set today. bottom connection on relay is live to battery. right hand tab is ground. Left hand tab is main beam on/off which is the blue/yellow wire. Top tab is connection to spotlight. Don;t worry about earth as the bracket earths the light. hope it helps!!
Old Dec 25th, 2006, 07:57 AM
ok run that by me again here are the wires i got left when i take the ones that go to spots away.
Old Dec 25th, 2006, 08:00 AM
if you have the original bmw spot wiring loom thenbmw have to activate it what we are talking about is using a relay thereby avoiding the horrendous bmw costs!!
Old Dec 25th, 2006, 08:14 AM
yes its original wiring loom i was just trying to see if i could mod this one to just connect to high beam wire, instead of going to the ecu.
russ
Old Dec 25th, 2006, 08:28 AM
you are much better off getting a cheap relay so you can run the spots from the battery with just the power drain from the main lights being to switch the relay. I don't know what problems could be caused by using the main beam power to also do the spots ?!
  #15 (permalink)
Old Dec 25th, 2006, 03:59 PM
just looking at loom i take it the left wire is a live feed to relay? the one on the right are earths? and the short brown and white is to ecu? would this be correct?
Wipac Spot lights and wiring Mini Mic First Generation MINI Exterior 42 Oct 2nd, 2008 08:23 PM
Wipac Spotlights bones` First Generation MINI Exterior 13 Sep 5th, 2007 08:38 PM
wiring spotlights Pep71 First Generation MINI Exterior 9 Jul 23rd, 2007 09:06 AM
Fitting Wipac spots James First Generation MINI Exterior 9 Oct 9th, 2006 04:29 PM
