Expert Advice Required - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 25th, 2006, 09:13 AM
BDL's Avatar
BDL
Local Time: 08:35 PM
England Male View BDL's Chili Red & Body Color 1st Gen MINI Cooper Profile
Fast and Dirty. When fitting Spotlight Brackets (OEM Type), Pop Rivets or Self Tappers?
Your thoughts?
Old Aug 25th, 2006, 09:21 AM
Rakey's Avatar
Total MINI dot com!!
United Kingdom Male View Rakey's Classified Ads
pop rivets, far more secure and tidy
Old Aug 25th, 2006, 10:09 AM
Richard82's Avatar
Toot toot, honk honk!!
Local Time: 07:35 PM
United Kingdom Male View Richard82's Hyper Blue & White 1st Gen MINI Cooper S Profile View Richard82's Classified Ads
I'm just in the process of fitting my lights and not to sure how to secure the top part of the bracket. I can do the bottom two fine but where the hole for the top aligns is straight onto the bonnet, so I can't exactly drill there!! Does anybody have pictures of where the top of their brackets sit. I have got the official BMW mini install sheet but the actual brackets are third party off ebay. Your help would be much appreciated!
Old Aug 25th, 2006, 10:26 AM
Richard82's Avatar
Actually it may not be the bonnet. Do I have to remove a black plastic strip to get in behind the top mounting location?
Old Aug 25th, 2006, 11:20 AM
Aberdeen Al's Avatar
United Kingdom Male View Aberdeen Al's Classified Ads
I secured mine using set screws, nuts & spring washers (prevents nuts falling off due to vibration).
Vroooom Vroooom
Old Aug 25th, 2006, 03:17 PM
BDL's Avatar
BDL
He nicked my thread............
Old Aug 25th, 2006, 03:21 PM
Richard82's Avatar
Sorry BDL, more adding on then nicking Thought I would eliminate the need to start a new thread!
Just one more question, are there different size brackets as I really cant get mine to meet the underside of the bonnet at the top hole. There is a gap of about 1cm even when I push the bracket close to the grille.
Old Aug 25th, 2006, 03:24 PM
BDL's Avatar
BDL
No probs Rich
I must say, I have yet to offer up my brackets so cannot help on that. I'm hoping to do the install this weekend so either a success or a horror story is on its way!!
Old Aug 25th, 2006, 05:33 PM
A tip ; if you are fitting spotlights (oem) , the dealers when they fit them , fit the upper rivet ,( its to stop the lights vibrating back and fore) through the plastic grill , over a short period of time the rivet pulls through the plastic and the rivet just dangles,and the lights vibrate, fit the rivet through the metal at the top , then the rivets stay in place - no more wobbly lights, it is also tidier to run the loom at the back of the plastic bulkhead out of sight ,and not just lay it in anywhere and use a load of tywraps. you can adjust the beams against a wall at night they should form a nice symetrical pattern equally spaced between the main beams and the same height-Adam
Old Aug 25th, 2006, 07:08 PM
BDL's Avatar
BDL
A quality set of tips! Thanks Very Much
Old Nov 12th, 2006, 02:50 PM
drumzz's Avatar
i have this vibrating problem..where are the rivets and how do u stop the lights vibrating? much appreciated
Advice required... Little Plato General Discussion 9 Mar 10th, 2005 07:44 PM
Advice Required? J0nesy General Discussion 15 Mar 6th, 2005 06:40 PM
Advice required please ButtonIt Wheels, Tyres & Brakes 11 Oct 2nd, 2004 09:05 AM
Photoshop Expert Required! SamEllis First Generation MINI Exterior 4 Mar 31st, 2004 06:44 PM
advice / help required The Saint General Discussion 3 Feb 19th, 2004 10:30 AM
