| | LinkBack (3) | Thread Tools | Rate Thread |
| I've just bought the same kit on fleebay and had to order a wiring kit as i found 1 wasn't included couple of questions Since there aren't any templates for the brackets is it obvious how they fit/ where to drill? There's just 1 wire from each lamp - i asume this is the positive so how do you earth them? Thanks |
| Hi Robby Have a look at these instructions for fitting BMW spot lights. Ignore everything but have a look at section 5 where it tells you the measurements and where to drill holes. www. BMW_Driving_lamp_install.pdf I had a look at the wipac wiring kits but ended up making my own as i wanted a fused relay and didnt want to use the switch they included. Anyway... its all straight forward once you get started. The Wipac lights earth themselves inside the housing which inturn earths through the brackets and through the screws/rivets used to fasten to the car body. Have a look at the wiring diagram Richard provided. Note:... make sure you get the relay which is the same.. otherwise the wiring will be slightly different. Incidently.. my relay was slightly different... basically the 85 & 86 were the opposite way around. Post your pics once youve finished.. If you have any questions.. post them too! Goodluck! |
| I just recieved my set of quad Wipac lights in post. The instructions are terrible for fitting them. The electrical side is ok, as i was an electriian in a previous life, but the bit where you have to drill out for the brackets kind of scares me especially as the re are no diagrams ![]() |
| Call in at Ouston and fit mine will you MINI MIC Car's currently in workshop getting fixed but wouldn't mind seeing how it's done before I do it to mine next month .Went to the NEMC years ago, but was a but cliquey and not very open. Is it changed? - I'm probably getting a matching classic soon to the Velveteer, so at least I won't be one of those BMW mini drivers!! |
| Robboc, I had no diagram, I set mine up using 4 brackets, the other alternative is to use the bar which is only attached at 2 points and would indicate where the brackets would have to go. When fitting four brackets there is only pretty much one place that each bracket can go. Just push them through and line them up yourself. My brackets are right by each other but one of each on either side i.e. on each side of the car I have bracket that goes to the left and one that goes to the right. Also make sure that where the nut/bolt or self tappins screw will come up through is not obstructed by one of the uprights on the grill. |
| Hi Monkeyhanger The NEMC is under new management as of 1-2 year ago... Its a great improvement over previous attempts to make it better.. Its no longerthe clickey atmosphere it used to be. Get yourself along! You'll be impressed with the amount of Minis and Binis that attend the club. Richard...... Stamfordham??? ah im guessing you dont live in Newcastle upon Tyne? Thats where i assumed you lived. |
| Well, not technically, but it's part of my postal address! I live in Ponteland, by Newcastle airport, there are two Ouston's in the region:Searching for ouston found 2 places I am quite near number 1! |
| Hi All, very informative, thank you all for the info, I too bought mine off ebay and obtained the Relay and connectors from local spares shop, Fitted them yesterday took around 2.1/2Hours. One thing though I have seen on some post's that BMW have to activate them and make a changes to the ECU whats all that about??? |
| Tags: aux lights, driving lights, spot lights, spotlights, wipac, wiring |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-exterior/125958-wipac-spot-lights-wiring.html | ||||
| South Coast New MINI Club: Forums / Exterior / Lights! | This thread | Refback | Jan 23rd, 2009 08:46 PM | |
| South Coast New MINI Club: Forums / Exterior / Lights! | This thread | Refback | Jan 23rd, 2009 07:36 PM | |
| South Coast New MINI Club: Forums / Exterior / Lights! | This thread | Refback | Jan 23rd, 2009 05:18 PM | |
| Wipac Spotlights wiring.. | ScottyBoy | First Generation MINI Exterior | 26 | Feb 4th, 2012 11:47 PM |
| Wiring for spot lamps | danb | First Generation MINI Exterior | 7 | Feb 19th, 2006 09:08 PM |
| spot light wiring kit | "Reedy" | First Generation MINI Exterior | 0 | Oct 1st, 2005 09:48 AM |
| Spot Lamp Wiring Advice Required Please? | J0nesy | General Discussion | 23 | Aug 17th, 2005 10:24 PM |
| wiring Bmw spot lights | Blackaeromini | First Generation MINI Exterior | 5 | Apr 1st, 2005 08:23 PM |
