Wipac Spot lights and wiring - Page 3 - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (3) Thread Tools Rate Thread
  #31 (permalink)
Old Oct 29th, 2006, 06:46 AM
burns863's Avatar
The Muffin Man
Local Time: 10:06 PM
United-Kingdom
Still not received my lights hopefully get the monday! iv taken a look at the pdf, but i am unsure on where the drilling is to be done? and does it really have to be drilled or can i get around this? very worried about drilling my mini
  #32 (permalink)
Old Oct 29th, 2006, 09:25 AM
Left
Hi folks,
Mini's back from an extended stay at the BMW garage - details off-line in the pub some day ( You lot still meet in the pub outside the Nissan gates? )
( I'm in the second Ouston, down by chester-le-street ! )
Let me know how the wipacs go - look much nicer than the Hella's! ( And cheaper )
Stew.
Mid-life Crisis Biker and Kit-car builder...
  #33 (permalink)
Old Oct 30th, 2006, 05:21 PM
burns863's Avatar
The Muffin Man
Well I have just received my WIpac's and they look great! Bit scared about the wiring, i shouldnt be as I am an undergraduate electronic engineer, but I hate messing with my MINI as I just dont want to break it!! haha
The drilling is scaring me, and even from the bmw pdf file i dont really get the fitting and drilling
aaaaaaaah what am i going to do?!?!
  #34 (permalink)
Old Oct 30th, 2006, 07:47 PM
Left
Bring it here - I've got a blunt 13mm drill bit that should do...
More helpfully - has anyone got the factory brackets and can measure from the edge of the grill where the drill-holes go and put some piccies in??
  #35 (permalink)
Old Oct 30th, 2006, 08:01 PM
Left
Just remembered Hat's got some piccies in his gallery of the Hella brackets, that might help. Not seen the wipac.s so not sure.
Also found this in the gallerys
http://www.mini2.com/galleries/data/500/brackets.jpg
  #36 (permalink)
Old Oct 30th, 2006, 08:45 PM
burns863's Avatar
The Muffin Man
cheers monkeythanger that is great! If you find any more pics post them up
  #37 (permalink)
Old Dec 18th, 2006, 10:36 PM
Local Time: 11:06 PM
can you not just splice straight into the main beam wire or do you have to fit a relay and fuse?.
  #38 (permalink)
Old Dec 18th, 2006, 11:28 PM
DIY
You need a relay mate for when you are switching the lights on and off....don't let it worry you. I did mine myself and they look great. If anyone is worried about the spacing of the brackets then do what I did and drive round a carpark till you see another mini and dive out with a tape measure!! The brackets actually sit in the correct place when you offer them up through the grill. I was a bit worried too but I needant have been. They are easy to fit. I recon Id be able to do em in an hour now Ive done one set. You feel better too knowing you saved £230 in the price the dealers want to charge......they wanted £300 in Sheffield....nearly choked on my drippin' butty !!!.....ha ha
It's gotta be yella'
  #39 (permalink)
Old Apr 26th, 2007, 02:21 AM
play fife's Avatar
The Invisible Boy
Send a message via MSN to play fife
Local Time: 08:06 AM
Australia Male
I have 2 Wipac spot lights on order, is the photo of that blue mini on page 1 of this thread Wipac lights, if so im very impressed how OEM they look.
Btw my Wipac lights arnt stainless steel, anyone know how to avoid getting rust, any treatment i can rub on ?
Daniel
2004 DS/W Cooper S 17" S-Spokes, Sunroof, iPod AUX input
2006 NRL Premiers - Brisbane Broncos
  #40 (permalink)
Old Jul 10th, 2007, 08:02 AM
play fife's Avatar
The Invisible Boy
Australia Male
Check out post #6277.
http://www.mini2.com/forum/australia...-mini-314.html
Daniel
  #41 (permalink)
Old Nov 29th, 2007, 12:00 AM
England Male
Hi all,
I hope I am on the correct thread.
I am after some wipac spots (just the two spots) for my 2004 cooper s (pre facelift).
Few questions!
Where's best to buy them from(links would be great)?
Does the ECU need re-programming for Wipac spots?
Thanx
  #42 (permalink)
Old Mar 16th, 2008, 11:32 AM
Hello
i have a 52 plate cooper and i have got some wipac spot lamps. I have the wiring loom that came with it put to be honest iam not that sure how to fit them. Wondered if anyone can offer some help
Many thanks
Ben
  #43 (permalink)
Old Oct 2nd, 2008, 09:23 PM
Wipac spot lights
Just bought a set of spot lamps with fittings for my MIni One, however I have been given no fitting instructions. Cant see a clear way to install.
I have been supplied the following:
- Spot lamps
- x2 metal plates
- all wiring
- x2 brackets
Any suggestions or help?
Tags: , , , , ,
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-exterior/125958-wipac-spot-lights-wiring.html
Posted By For Type Date
South Coast New MINI Club: Forums / Exterior / Lights! This thread Refback Jan 23rd, 2009 08:46 PM
South Coast New MINI Club: Forums / Exterior / Lights! This thread Refback Jan 23rd, 2009 07:36 PM
South Coast New MINI Club: Forums / Exterior / Lights! This thread Refback Jan 23rd, 2009 05:18 PM
Wipac Spotlights wiring.. ScottyBoy First Generation MINI Exterior 26 Feb 4th, 2012 11:47 PM
Wiring for spot lamps danb First Generation MINI Exterior 7 Feb 19th, 2006 09:08 PM
spot light wiring kit "Reedy" First Generation MINI Exterior 0 Oct 1st, 2005 09:48 AM
Spot Lamp Wiring Advice Required Please? J0nesy General Discussion 23 Aug 17th, 2005 10:24 PM
wiring Bmw spot lights Blackaeromini First Generation MINI Exterior 5 Apr 1st, 2005 08:23 PM
