Wipac Spot lights and wiring - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (3) Thread Tools Rate Thread
  3 links from elsewhere to this Post. Click to view. #1 (permalink)
Old Sep 11th, 2006, 11:06 AM
Mini Mic's Avatar
Its not all small!
Local Time: 12:24 PM
United Kingdom Male View Mini Mic's Classified Ads
Hello
Im considering buying 2 Wipac spot lights for my mini.
My questions are:
Do i need to purchase the wipac wiring loom? But this loom comes with a switch and i want them wired into my main beams.. So do i just use the rest of the loom and leave out the switch?
Does anyone have a set of instructions for wiring these lights?
I dont understand relays and do i take the power from the auxilary battery terminal in the engine bay?
Any information/ advise would be great!!
Thanks!
Michael
Old Sep 11th, 2006, 12:40 PM
Richard82's Avatar
Toot toot, honk honk!!
Local Time: 11:24 AM
United Kingdom Male View Richard82's Hyper Blue & White 1st Gen MINI Cooper S Profile View Richard82's Classified Ads
Hey Michael,
Well I have just hooked up 4 Wipac lamps to the front of my mini and it wasn't too bad. I didn't have a wiring loom with switch, mine just come on with the main beam.
I had to splice the main beam going into the NS front light. This wire then goes to the little relay box which has one wire coming off attached to the headlight mounting bolt (earthing the circuit). Another wire runs down the NS of the bonnet, down the hinge, through the cowl area, in behind the centre cowl and then I drilled a tiny hole for the wire to come out by the +ve terminal.
The final wire goes off under the bonnet sound proofing material to a multi wire junction where 4 wires go off to each lamp.
The power for mine comes from the +ve battery terminal in the engine bay and is simply attached by a hoop end (can't remember what the are called!)
If you need any more help just let me know.
Richard
Old Sep 12th, 2006, 11:50 AM
Mini Mic's Avatar
Its not all small!
Hi Richard.
Thanks for the reply.
I see youre from Newcastle.. Same here.. well Washington.. just down the road.. You should get yourself to the North East Mini Club.. we meet every Thurs.
In reply to your post... Where did you get your relay and wiring loom from and what type would i need? Any suggestions?
Michael
Old Sep 12th, 2006, 12:19 PM
Richard82's Avatar
I will have to look into going along 2 one of the clubs, but Thursday is my 5-a-side night!
I actually bought mine on ebay with the Wipacs but to be honest all you need is the relay. The rest are just standard wires and connectors, this kit would do you (just ignore the flick switch). You could probably buy the parts individually for less as you don't need the switch. I have the numbers to which wire has to connect to on the relay and its just a case of routing round the engine bay.
You might need a crimping tool (or just pliers ) to squeeze down the connectors.
The other things you would need is 2 ring terminals (one for the earth and one to connect to the battery) and a 'tap-wire splice' which splices the OS drivers light, like this:
The female quick connect terminals in the pack would be used to attach the actual spot lights (they just pop in). I would also suggest a few little rubber surrounds for the connectors just to protect from the water that gets into the engine bay.
I could have saved a packet if I had only known this before!
Old Sep 12th, 2006, 12:26 PM
Mini Mic's Avatar
Its not all small!
Hi Richard
Ive been looking at getting this wiring loom which includes a relay.
Is this the loom you bought?
www.ebay - wipac - wiring loom
If you could let me know the numbers of which to wire to i would really appreciate it.
You should join the club. If only to get a membership which entitles you to Car Owners club discounts for insurance. The membership only costs a fiver and can save you up to 15% on your insurance premiums.
Michael
Old Sep 12th, 2006, 01:08 PM
Richard82's Avatar
I actually bought my kit second hand as I got it with the 4 lamps & brackets etc. That kit would be fine along with the extras I mentioned in the above post. I will draw a diagram of it this evening for you
Old Sep 13th, 2006, 09:54 AM
Richard82's Avatar
Michael here is a diagram I have put together. If it doesn't make any sence to you, let me know!
Old Sep 13th, 2006, 02:40 PM
Mini Mic's Avatar
Its not all small!
Richard Thats great!! Thanks mate!
Will that relay be available from any electrics store or is that the one you get with the wipac kit?
Old Sep 13th, 2006, 02:54 PM
Snowie's Avatar
Local Time: 01:24 PM
England Male View Snowie's Thunder Blue & Silver 1st Gen MINI Cooper S JCW GP Profile
Exclamation
Hi Guys
For safety sake use a fuse in the supply line from the battery to the relay - 15 amps in line fuse holder from any car accessory shop will do the trick. Never wire directly from the battery without an in line fuse.
Old Sep 13th, 2006, 03:01 PM
Mini Mic's Avatar
Its not all small!
Thanks for the info Snowie.. I will do just that.... infact that was my next question!
Michael
Old Sep 14th, 2006, 08:30 AM
Richard82's Avatar
Yeah I suddenly thought of that last night and was going to mention it this morning!
Old Sep 14th, 2006, 12:55 PM
Mini Mic's Avatar
Its not all small!
Thanks for all your help!
Hopefully the lights will arrive today or tomorrow and i'll be wired ASAP.
Will post a pic once its done!
Thanks again!!
Michael
Old Sep 18th, 2006, 10:16 PM
Mini Mic's Avatar
Its not all small!
Finally got round to installing the spot lights today. What do you think?
Richard... Thanks again for all your help!
If you see me around... Flash like a maniac and i will flash back
Name:	Spot Lights Mini2.jpg
Old Sep 19th, 2006, 10:40 AM
Richard82's Avatar
They are looking N I C E !!! Glad I could help you!
One other thing you could do is put some protective rubber/wire surround on the bits of wire that come out the bottom of the lights. I added some to mine the other day as they seemed to be getting misted up. I had some small rubber tube in the garage that I used, not sure if its needed though. It just goes back to the junction box on mine.
  #15 (permalink)
Old Sep 19th, 2006, 11:23 AM
Aberdeen Al's Avatar
United Kingdom Male View Aberdeen Al's Classified Ads
Did you remember to earth them as well?
Vroooom Vroooom
Tags: , , , , ,
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-exterior/125958-wipac-spot-lights-wiring.html
Posted By For Type Date
South Coast New MINI Club: Forums / Exterior / Lights! This thread Refback Jan 23rd, 2009 07:46 PM
South Coast New MINI Club: Forums / Exterior / Lights! This thread Refback Jan 23rd, 2009 06:36 PM
South Coast New MINI Club: Forums / Exterior / Lights! This thread Refback Jan 23rd, 2009 04:18 PM
Wipac Spotlights wiring.. ScottyBoy First Generation MINI Exterior 26 Feb 4th, 2012 10:47 PM
Wiring for spot lamps danb First Generation MINI Exterior 7 Feb 19th, 2006 08:08 PM
spot light wiring kit "Reedy" First Generation MINI Exterior 0 Oct 1st, 2005 08:48 AM
Spot Lamp Wiring Advice Required Please? J0nesy General Discussion 23 Aug 17th, 2005 09:24 PM
wiring Bmw spot lights Blackaeromini First Generation MINI Exterior 5 Apr 1st, 2005 07:23 PM
