| I've had this with both windows on both my MINI ONES, on my 03 ONE they fixed it by using lithium grease( sounds like something you would find on the uss enterprise). I took my current 04 ONE in for this a few months back and they said the windows were fine,NO THEY ARE NOT,they said that it was a little motor of some description in the drivers door that was making the noise(so why does the passenger window do it too)They replaced the little motor and its still squeaking. Not resolved. ![]() |
| It's rubber, for sure. The driver's window sounds more, because you use it more often. I haven't seen big difference when the window is wet or dry, but in summer it makes more noise than in cold time. I think the rubber just getting bigger because of the higher outer temperature in summer. |
| BMW has a special lubricant for all the rubber window and door seals. It is teflon gel made by a company called CarbaFlo. The tube says CarbaFlo KSP105. I don't recomend asking the price since you'll have a coronary. If they have any ask them to apply it for you. This is the replacement for the product referred to as "Gummi Pfledge." Be sure to remove all traces of silicone from the seals prior to treatment or the stuff won't adhere. |
| Screeching passenger window | IH1 | First Generation Faults & Fixes | 1 | Oct 19th, 2006 10:18 PM |
| Passenger window | the-ruff-puppy | First Generation Interior & Ice | 6 | Jul 26th, 2006 06:56 PM |
| Passenger Window | Chapmoni | First Generation MINI Cooper S | 10 | Jan 16th, 2004 08:38 PM |
| Passenger window goes down but not up... | ZekaFon | First Generation Faults & Fixes | 2 | Nov 4th, 2002 09:55 AM |
| Passenger Window | Bonnie Scotland | First Generation MINI Cooper S | 2 | Sep 15th, 2002 08:28 PM |
