Front grille badge - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 15th, 2006, 05:18 PM
GTT 280's Avatar
The Power Cube
Local Time: 04:00 PM
United Kingdom View GTT 280's Classified Ads
Question Front grille badge
All,
Does anybody know how the front JohnCooperWorks badge is fitted to the front lower mesh grille next to the number plate?
I want to remove it, but it appears to be part of the mesh, surely it can't be, it must be fixed somehow, but there is no flex on the edges of the badge, so it is well fitted - glue or fastened?
I also want to fit a new badge that is flat aluminium - does anyone know the best approach for fitting this metal to plastic?
Superglue - damage to grill? will it hold the metal?
Silicone Sealant - tried this but the badge pulled off easily.
Drilling and bolting - how do i weld a bolt to aluminium?
Cheers,
K.
Old Nov 15th, 2006, 09:45 PM
mGP's Avatar
mGP
Local Time: 03:00 PM
I could be wrong; but I believe it is screwed/bolted in from behind (X2: one either side) as I remember seeing an exploded diagram of it somewhere.
Old Nov 15th, 2006, 10:05 PM
mGP's Avatar
mGP
This should help put thing's into perspective;
Last edited by mGP; Nov 15th, 2006 at 10:09 PM. Reason: Replaced eBay link with picture; might get told off!
Old Nov 16th, 2006, 07:15 AM
GTT 280's Avatar
The Power Cube
Thumbs up Good work!
So it is bolted in position. Nice work mate.
Now, how do i reach underneath to get at those bolts - (joking) I'll find a way.
Cheers,
K.
Tags: , ,
grille badge holders wiz First Generation MINI Exterior 4 Oct 2nd, 2006 03:01 PM
front MC badge replace for smaller MCS badge? tyrerc First Generation MINI Exterior 3 Aug 31st, 2006 11:31 AM
Grille badge? blueskylee General Discussion 0 Sep 2nd, 2002 04:09 PM
