Reverse lights not working - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 6th, 2007, 08:14 PM
Local Time: 03:21 PM
Hello,
Ok, so I have a 2002 mini. The reverse lights stopped working. I have checked the normal things...ie fuse box under steering wheel and the bulbs, but I cant seem to figure it out. Anything I should should check...tips, clues, suggestions?
thanks,
Dell
Old Mar 6th, 2007, 09:49 PM
SteveM3's Avatar
Local Time: 08:21 PM
The most common problem on any car including the Mini is wear on the switch that
goes into the gearbox. If you are under w/tee that should be covered. Page 230-5 in
the Bentley manual if doing it yourself. If replacing the switch doesn't do it you'll need
to use a multimeter and check each stage of the wiring .
Old Mar 7th, 2007, 09:28 AM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
I agree it sounds like the switch on the gearbox there's been a few people on here that have had to replace them.
You didn't specify whether it was for a Cooper or S so for the 5 speed it's part 12 here
For the 6 speed it's part 6 here
It was acceptable in the 80's
Old Mar 7th, 2007, 09:30 AM
marx87's Avatar
R56 MCS Works For Sale!
I had the same problem my reverse light wasnt coming on. Mine was an 04 mini One. Strangely i was just about to take it to the garage and it started working again.
Old Mar 7th, 2007, 11:08 AM
Hey,
Thanks for all your replies. It is an 02 5 speed. I will check these this.
Dell
Old Mar 7th, 2007, 06:54 PM
Hello again,
Does anyone know where I can get this part (backup switch)? Can I just go to like an Autozone type place or should I order the part online? I have sort of looked around and not had much luck.
Thanks for your help,
Dell
Old Mar 7th, 2007, 08:12 PM
Quote: Originally Posted by Cally95 (original)
Hello again,
Dell
MINI are your best bet. Unlikely anywhere else would stock this part. Just quote the part number to your local dealer over the phone and they should be able to give you a price. In the UK at least the parts are pretty cheap compared to other makes.
Old Mar 11th, 2007, 03:38 PM
I have another question that is a little wierd. When you put the car in reverse (5 speed manual)
which lights come on? The little 1 in the middle on the lower bumper? or are there 2 in the back? Thanks, I cant remember now.
Dell
Old Mar 12th, 2007, 03:48 PM
On a 2002 MINI it's the lamp in the centre of the bumper. The face lift models (July 2004 onwards) have the reverse lights in the rear lamps and a foglight in the centre of the bumper.
Old Mar 12th, 2007, 04:06 PM
vigilante's Avatar
...for now we drift!
Send a message via MSN to vigilante
Hi Cally - we traced the same problem in my 2002 mini one to the bulb holder in the reversing bulb assembly - it only cost about equivelant of $4 for a replacement from the local MINI/BMW dealership but took 5 weeks to get in from Germany. Just a pain to get to to replace it.
way to check it is take off the spare wheel tray (4 screws) then take the bulb holder from the connector and use a circuit tester to check if their is a current when the car is put into reverse at ignition II.
hope this helps
Old Mar 12th, 2007, 11:56 PM
Thank you
Old Mar 20th, 2007, 01:44 PM
Ok, so I am still working on the electrical issue I am having with the reverse lights, but I had another curious question. When I press the unlock button on the key chain to unlock the car with the remote NO lights come on except the interior. Is that normal? When I press the lock button on the remote other rear exterior lights blink. I am wondering if I am having other issues here and I want to check them as a whole.
Thanks,
Dell
Old Mar 20th, 2007, 04:23 PM
vigilante's Avatar
Dell...thats the same as mine - get confirmtion of locking the car by one flash of indicators and side repeators and confirmation of unlock by all interior lighting coming of for 30 seconds or until the engine is started. This was the same on my mates 2003 cooper s also
Old Mar 20th, 2007, 05:29 PM
Thanks,
Dell
This is normal. Lock you get one flash of the hazards, unlock the interior lights fade up.
  #15 (permalink)
Old Mar 20th, 2007, 10:26 PM
Thank you guys for all your help,
So the saga continues. I have checked the circuit in the light and socket itself and all is good so I am back to the back up switch. Previous post told me it is next to the gearbox...thanks for the link Root Ginger. I ordered the part and I have it. My mechanic friend that was going to put it in, no longer can help me...so I am on my own. Is the back-up switch somewhere that I can reach it? Is it in the engine area or under the vehicle? Can a normal non mechanic but handy person put in the new back up swtich?
Thanks you for all your help!!!
Dell
Interior map lights not working Westy First Generation Faults & Fixes 5 Mar 5th, 2006 03:27 PM
both brake lights are not working hamster100 First Generation Faults & Fixes 5 Jan 13th, 2006 02:03 PM
Walk you home lights, Not Working. Minnington General Discussion 13 Jan 10th, 2006 07:33 AM
Reverse light is not working.. leon1982 First Generation Faults & Fixes 3 Jun 18th, 2004 10:30 PM
Interior lights not working!!!! miniads First Generation Faults & Fixes 8 Nov 13th, 2003 08:20 PM
