Wobbly Wipacs - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 21st, 2007, 12:42 PM
jamski's Avatar
'Jack the Black' Cooper
Send a message via MSN to jamski
Local Time: 04:02 PM
United Kingdom Male View jamski's Cosmos Black & White 1st Gen MINI Cooper Profile View jamski's Classified Ads
Wobbly Wipacs
I fitted Wipac spot lights a couple of weeks ago, a breeze to install and look the nuts, but only drove with them on for the first time last weekend, and although I was expecting them to move, they really do, quite a bit.
It looks like the lights are flickering, and although the the signs are lit up like a christmas tree, it's like they're almost flashing! It was worse on bumpy lans, but even on motorways I still get a far bit of shake. I fitted them with pop rivets, so it is just the bracket wobbling I guess. Is this normal movement, is there anything I can do to reduce it?
Cheers everyone,
James.
Old Jun 21st, 2007, 01:59 PM
Step_7's Avatar
Whining....
Local Time: 03:02 PM
Northern Ireland Male View Step_7's Dark Silver & White 1st Gen MINI Cooper S Profile View Step_7's Classified Ads
I did mine with pop rivets and I can see the odd vibration if I hit a pothole but in normal use they really don't move much at all.
Old Jun 22nd, 2007, 10:20 PM
R99's Avatar
R99
United Kingdom Male View R99's Chili Red & Black 2nd Gen MINI Cooper S Profile View R99's Classified Ads
The OEM lamps have a small rubber coated screw which is drilled through the grille. This presses itself onto the lamps and because its applying pressure, it stops pretty much all vibrations. You cant see it, because its behind the lamps themsevles.
Maybe you could try a similar soloution, but it depends if you want to drill your grille or not I suppose.
Regards,
James.
::.. 2007 JCW Stage 1..::
--- Modern MINI Oscars Winner 2008 ---
Old Jul 10th, 2007, 07:04 AM
play fife's Avatar
The Invisible Boy
Send a message via MSN to play fife
Local Time: 01:02 AM
Australia Male
A small bit of rubber might help, thats what im gonna do with mine as mine vibrates alittle.
Daniel
2004 DS/W Cooper S 17" S-Spokes, Sunroof, iPod AUX input
2006 NRL Premiers - Brisbane Broncos
Tags: , , , ,
Wipacs stopped working. HELP. Pep71 First Generation MINI Exterior 1 Oct 7th, 2007 08:42 AM
spot lights/wipacs Mess First Generation MINI Exterior 7 Sep 26th, 2007 04:05 PM
having trouble with my wipacs sobaphobic First Generation MINI Exterior 3 Sep 24th, 2007 01:40 PM
wobbly seats!!!! ..Blackadder.. First Generation Faults & Fixes 1 Mar 9th, 2007 09:29 AM
Wobbly gearstick phil_wkl First Generation Faults & Fixes 3 Mar 1st, 2006 01:06 PM
