| Well that's my last resort. If the thread is knackered and I can't get them off, then I'll have to cut them off - any advice on cutting them off? What about the brackets holding them to the grill, how did you get them off? They've got some weird allen heads I think. |
| I took mine off this past weekend to replace them with new ones and the only way i could find was to drill a small hole the inside and jam the bit in it to stop the bolt from spinning hope this helps |
| I Had exactly the same problem a few weeks ago, What i did is take the front lens off as you did cut the wires with enough length to attach them back together the drill the bolt off i then got another bolt machined at work, re-attached the wires and put the new grill on and re-fitted the lamps. Have you had this sorted yet?????? If not i can possibly get another bolt made for you so you can drill it out! Scott |
| Tags: spot lights |
| Spot Lamp Wiring Advice Required Please? | J0nesy | General Discussion | 23 | Aug 17th, 2005 10:24 PM |
| Spot Lights | CNred | First Generation MINI Exterior | 5 | Oct 23rd, 2004 01:02 AM |
| spot lights | ono | First Generation MINI Exterior | 3 | May 12th, 2004 10:25 AM |
| Help!!!! Anyone got 4 spot lights?? | spillers | First Generation Interior & Ice | 1 | Mar 31st, 2004 08:04 AM |
| Spot Lights | IgorTheHunchback | First Generation MINI Cooper | 4 | Jun 20th, 2002 09:42 AM |
