Spotlights help! What am I doiing wrong? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 6th, 2007, 10:51 AM
Adam101's Avatar
Local Time: 04:04 PM
United Kingdom View Adam101's Cosmos Black & White 1st Gen MINI Cooper Profile View Adam101's Classified Ads
Angry Spotlights help! What am I doiing wrong?
Hey peeps!
I've bin wiring some spotlights onto my 2002 cooper. I got some cheap black spotlights from ebay some brackets from newministuff and a bog standard wiring kit (relay,wires, fuse etc.). Tried wiring it up and the lights weren't working.
Connected the wire with fuse (red) to battery and relay, connected green wire to green/blue wire in OS headlamp, connected black to a headlamp fixing point as an earth and connected the blue wires to the lamps.
What am I doing wrong?
I'm thinking it may be because The lamps aren't earthed individually but I can't see how I would earth them because the bulb only has one wire coming off it. Its an h3 bulb. Am I missing something?
Any help would be great! Thanks in advance!
Adam
Old Sep 6th, 2007, 10:57 AM
hi im not sure about fittings etc, but i am thinking about getting some spots for my mini as well, how much hve you spent on them? do they look good?
Old Sep 6th, 2007, 11:48 AM
Adam101's Avatar
Hi mate! They look awesome! I wanted black ones to match my aero grille, found some on ebay for £6.99 + delivery, £30 for brackets, £8 for wiring. Will get some pics upwhen I'm finished!
Old Sep 6th, 2007, 11:50 AM
Richard Crofts's Avatar
THE STICK
Local Time: 03:04 PM
Ummmm. ... speak to Mikey at newministuff or Dave from auto-tech-solutions ??
Its all techo gabble to me unless I can see what I am advising on when it comes to wiring
Old Sep 8th, 2007, 04:16 AM
minimattsback's Avatar
Going up in the world
Use this link for details on wiring. The earth is achieved through the bracket so good contact is required.
http://www.mini2.com/forum/exterior/...ghlight=relays
Old Sep 10th, 2007, 09:03 AM
Adam101's Avatar
Cheers mate. Seems i've tried everything I can but still have had no success. I'm just going to take it to an autoelectrician (there's a good one near me). Thanks for everyones help anyway!
Adam
Old Sep 10th, 2007, 01:29 PM
J8YMP's Avatar
United Kingdom Female View J8YMP's Dark Silver & Black 1st Gen MINI Cooper S Profile View J8YMP's Classified Ads
I'm no expert on this, but I spoke to a lady y'day at Stanford Hall and she said something about having them programmed??? Hers was a brand new one though
Old Sep 10th, 2007, 01:56 PM
ohsoblue's Avatar
My brain hurts!
United Kingdom Male View ohsoblue's Pepper White & Black 2nd Gen MINI Cooper Clubman Profile
Red Cooper
The wire for high beam is the Yellow one with a Blue Tracer that goes into the back of the O/S headlamp. On mine I also have seperate earths on both lamps that go to the mounting brackets and also another earth cable that goes to the N/S bonnet hinge earth stud. Sounds like you've picked out the wrong high beam feed.
Old Sep 10th, 2007, 03:06 PM
James's Avatar
England Male
make sure you haven't accidentally blown the fuse when installing them...I had that problem
Old Sep 17th, 2007, 03:34 PM
Adam101's Avatar
Just to keep people posted, The lamps were faulty and were not earthing properly inside! This has been corrected now but thanks for everyones help in the meantime.
Old Sep 18th, 2007, 08:18 PM
R99's Avatar
R99
United Kingdom Male View R99's Chili Red & Black 2nd Gen MINI Cooper S Profile View R99's Classified Ads
What do they look like then? You were after some black ones werent you?
::.. 2007 JCW Stage 1..::
--- Modern MINI Oscars Winner 2008 ---
Old Sep 21st, 2007, 12:19 PM
MiniMadMarshy's Avatar
United Kingdom View MiniMadMarshy's Classified Ads
Careful when wiring Wipacs up to the relays for your existing headlights guys I did this on my 03 cooper and it fried them because the ECU had not been reprogrammed to compensate for them, ended up having them wired up to a separate switch that I fitted under the headlight level dial
Tags: , , , , , ,
spotlights geezer296 First Generation MINI Exterior 1 Aug 23rd, 2007 03:10 PM
4 spotlights garyb1 First Generation MINI Exterior 10 Oct 31st, 2006 06:51 PM
spotlights den123 First Generation MINI Exterior 0 Jul 2nd, 2006 02:10 PM
spotlights fireman01 First Generation MINI Exterior 4 May 12th, 2006 01:56 AM
