| He's a busy man Rams, sure he get a reply sorted at some point. I dont think as much effort will be needed as the arches do because there will not be as much flex in these covers but as you say you will need to get rid of the orange peel effect then they can be sprayed as normal. Scott |
| No rush Rams, it can wait. Any info you can provide me with would be gratefully recieved, such as: did you do it yourself did you have to rub the surface down to make it flat and smooth what sort of paint did you use and where did you get in the MINI colours did you use primer and how did you go about painting the MINI logo in a different colour. Hope you have a good stag do by the way! Ta, Mike |
| did you do it yourself No, a lad I know down at BMW did them did you have to rub the surface down to make it flat and smooth Yes they have to be flatted down to make the primer stick what sort of paint did you use and where did you get in the MINI colours Genuine paint from BMW, using the sereal code from your car will get an exact match did you use primer yes and how did you go about painting the MINI logo in a different colour I think he just masked off the Mini logo the stands off the caps |
| He doesn't work for them anymore but he did my colour coding on my trims. He's a perfectionist orright, how about aksing him for colour coding the car for you like mine. I've never seen and Indi Blue Coded before but I bet it looks great. Cost wise it'll be about £300 all done, which is a saving of around £600 on BMW prices Rams |
| http://i107.photobucket.com/albums/m...HB2007PIC3.jpg See also the Heartbeat Run thread http://www.mini2.com/forum/uk-irelan...o-see-now.html Perhaps watch the video to see it in person! Rams |
| Tags: coding, covers, spot |
| Special Offer: MINI Spot Lamp Covers - 1st Gen | chris@LloydBlackpool | Lloyd Blackpool MINI | 59 | Aug 16th, 2010 02:15 PM |
| Spot Lamp Covers | Catskins | First Generation MINI Exterior | 11 | Apr 21st, 2007 12:20 PM |
| Spot Light Covers.... | Rico_Swarve | First Generation MINI Exterior | 2 | Sep 21st, 2006 12:37 PM |
| spot light covers | Jordan210 | First Generation MINI Exterior | 8 | Mar 16th, 2006 01:11 PM |
| Spot Light Covers | MINIALEX | First Generation MINI Exterior | 22 | Apr 14th, 2005 06:05 AM |
