| swapping out door lock cylinder My 2005 MC had a house key (?) broken off in the door's keyhole in an act of vandalism. I've ordered a replacement key cylinder and it's at the dealership. The part was $70, but they want $270 to install it ("labor"). I think that's outrageous! I've searched and searched the Bimmer forums and here, and I can't seem to find a detailed description on how to do this myself. Lots about inside panel removal and other door issues, but not this. I know about the two grommets in the edge of the door and the allen screws behind them. Does the inside door panel have to be removed at all? Before I attempt this, I would like to know if anyone here has done it and can provide tips or cautionary information. What I'm not clear on is this: Is the cylinder in a module that pops out from behind the handle once the door handle is lifted up, or after some clips are released? It seems like it's fairly easy to do this. Is it? How can my dealership demand such high labor charges for what sounds like a 15 min job? Thanks for any help. David |
| By "door card", do mean the interior door panel? I was more or less expecting that. Still, I'm pretty sure the door handle comes off easily from what I've read on the BMW sites, and, respectfully, it doesn't sound like you've actually removed a door handle yourself, so perhaps there's an easy trick to it. I've read that it's very hard on the 2nd Gen MINI (R55+), but very easy on the 1st Gen MINI. However, nothing more specific than that, since it was an R56 thread that I was reading. Sigh... David |
| After I wrote you, I went to North American Motoring and found some photos of the inside of the door (literally, the INSIDE), taken from the front aspect towards the back. The topic was "actuator replacement", but It showed me all I need to know about replacing the door lock module on the driver's side. My only unknown now is exactly how the door handle connects to the cable, but I will study the one that's in place now, and hopefully it will be obvious. At least now I'm confident enough to proceed. I have seen the door from both sides now (apologies to Judy Collins). ![]() David |
| Were you successful in replacing your door lock? I have to do the same after replacing my entire door. I have the door handle off and removed a bolt that secures the door lock, but it doesn't want to come out very easy. Perhaps there is a simple release mechanism to allow the actual lock cylinder to come out. Any help would be appreciated. Thanks '03 LY/B MCS |
| I'll be honest with you. I worked my ass off to hook it up, but physically, it was super hard. In the end, I gave up and had a local mechanic (specializing in BMWs) take over. It took HIM 4 hours and he said it was the hardest one he's ever done! My recommendation: take it to MINI on this one. It's just not worth the anguish. They know the tricks. The problem is that the space is so tiny and narrow, you can't work within it. |
| Tags: cylinder, door, lock, r52, r53, replace, swap |
| Door lock problems | Mark_Ohio | First Generation Faults & Fixes | 3 | Mar 28th, 2007 05:11 PM |
| Aluminium door pins... (door lock buttons) | GTT 280 | First Generation Interior & Ice | 3 | Jan 12th, 2003 06:31 AM |
| remote door lock help! | MAXIMINI | First Generation Faults & Fixes | 3 | Sep 2nd, 2002 05:49 PM |
| Door lock pins | monsta | First Generation Interior & Ice | 11 | May 3rd, 2002 04:25 AM |
