Fitting Facelift rear lights to pre-facelift car - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 27th, 2008, 01:11 PM
Local Time: 04:07 PM
Ok guys, managed to bag a bargain last night on ebay £16 for a set of facelifted rear lights, as i'm starting to theink the clear rears look a bit chav. Anyway, What do i need to wire them up, i wanted to leave the reverse in the bumper and use fogs in the main lights.
I see on REALOEM that BMW offer a retrofit kit for facelift lights, do i need this or is it simple. many thanks
Oh and i also bagged a brand new boxed set of Clear lens Wipac spots last night fo £19. God bless ebay.
Old Feb 27th, 2008, 01:31 PM
Paul's Avatar
MINI2 No.1
Local Time: 03:07 PM
England Male
You can do it yourself but you need to splice/cut wires etc (not hard, but might be scary). Or get the kit.
Old Feb 27th, 2008, 02:00 PM
splice wires it is then
Old Feb 27th, 2008, 06:32 PM
scraggles's Avatar
United Kingdom Male View scraggles's Pure Silver & Body Color 1st Gen MINI One Profile
If you want to use fogs in the main (facelift) lights the existing wiring will do that.
The lights are a straight plug swap for the pre-facelift lights, but the fog lights have become reverse lights so when you switch on fogs the reverse lights will show.
Either put red bulbs in place of the reverse lights, or do the wiring splice Paul refers to.
Here's a link where he does a great job in illustrating the exact splices needed:
http://www.mini2.com/forum/exterior/...ml#post1200693
can i fit facelift rear lights to a 51 reg parklaneuk First Generation MINI Exterior 8 Dec 4th, 2007 12:20 PM
Fitting Facelift Bumpers to Pre Facelift Daley Express First Generation MINI Exterior 4 Jul 18th, 2006 01:55 PM
facelift rear lights on a '02' cooper puccamini First Generation MINI Exterior 2 Oct 13th, 2005 11:03 PM
