| You could just buy the DIY add on LED's - just order the amount you wish to add. So to make your halos 4 led you will need 2 extra per lamp=4, to make them 6 led you will need 8 NewMINIStuff.com |
| For DIY upgrading the older original dim blue Halo sidelights made by Ultra which sometimes fail MOT's for being too blue and or dim (and if you are happy with the standard 2 LED bulbs per unit) the following upgrade worked well for me :- To make them brighter and whiter, fit the following replacement LED bulbs (2 per sidelight) :- Prism LED Bulbs 12V T10 Wedge (bubble pack of 2 is £9.99 in Halfords) part no. LED501 4W (W = White, 4 = 4 x LED) Side & Tail 4 LED - White - Vehicle Lighting > Styling/Prism Bulbs > 12v Prism LED Bulbs Manufactured by Ringautomotive.co.uk Note: you can see 4 LEDs in end of the bulb rather than 1 LED in the standard dimmer type. To make them brighter and keep the blue tint, fit the following replacement LED bulbs (2 per sidelight) Prism LED Bulbs 12V T10 Wedge (bubble pack of 2 is £9.99 in Halfords) part no. LED501 4B (B = Blue, 4 = 4 x LED) Side & Tail 4 LED - Blue - Vehicle Lighting > Styling/Prism Bulbs > 12v Prism LED Bulbs Manufactured by Ringautomotive.co.uk Note: you can see 4 LEDs in end of the bulb rather than 1 LED in the standard dimmer type. To fit the new LED bulbs just pull out the 2 black rubber bulb holders from behind each unit in situ and replace the existing push-in LED bulbs, if any don't light up just turn the bulb around in the holder and it will. ![]() I have fitted the white Prism LED bulbs above, they show up well in daylight conditions and am sure they will pass the MOT with no problems now. |
| I think they're these ones:- 501 LED Extreme Power 1.5W 360 degree *::*LED 501/W5W Bulbs*::*LED Interior Bulbs*::*Autobulbs Direct Ltd - Xenon bulbs, car bulbs, wiper blades, headlight, Osram, Ring, Philips Daily driver - Black Magic SEAT Leon 2.0TDI Sport - slighty modified ![]() Weekend driver - Pure Silver Mini ONE |
| 501 LED Extreme Power 1.5W 360 degree *::*LED sidelight and side repeater bulbs*::*LED Exterior Bulbs*::*Autobulbs Direct Ltd - Xenon bulbs, car bulbs, wiper blades, headlight, Osram, Ring, Philips If you order 2 packs of 2 they work out at £25.00 |
| Bought a set of these to go in the standard sidelights, but they are too big for the hole where the bulb holder sits. Assume they fit no problem in the Halo sidelights?? Daily driver - Black Magic SEAT Leon 2.0TDI Sport - slighty modified ![]() Weekend driver - Pure Silver Mini ONE |
| Yes, the 360 degree type LEDs fit the Halos but can get stuck in when you pull out the rubber holder, which means removing the whole light unit to extract it with long nose pliers. They are also more expensive and not as bright as the 4 x LED Prism bulbs available from Halfords when I compared them a couple of days ago. I think because all 4 leds face forwards on the Prism bulbs. (See previous posts and pics from mini33 for full details). Try them, brighter and smaller :- Prism 4 LED White Bulb 501 from Halfords Price £9.99 3 For 2 on Selected Car Styling Products |
| Tags: brighter, halo, led, newministuff, sidelight |
| Halo sidelights & halo headlights | rubberj00 | Second Generation MINI Exterior | 13 | May 30th, 2009 03:51 PM |
| Modified Halo Sidelights - Another Great job by Mikeythemini | Damo | First Generation MINI Exterior | 58 | Aug 30th, 2008 09:41 AM |
| My new Halo Sidelights | Darthbladerni | First Generation MINI Exterior | 18 | Mar 21st, 2008 01:09 AM |
| Appeal To Anyone With Halo Sidelights - Mot | Cooper S Dan | First Generation MINI Exterior | 8 | Jan 20th, 2008 09:36 PM |
