Stripes questions - dealer vs aftermarket - different shapes? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Dec 1st, 2009, 10:55 PM
Local Time: 06:35 AM
Ireland
Ireland Stripes questions - dealer vs aftermarket - different shapes?
Hi all,
Just joined, and asking questions already.
Have a 2002 Mini Cooper and want to add standard type bonnet stripes.
I tried a cheap vinyl set from eBay, but found it difficult to get them fitting right near the grille.
The eBay set came as normal rectangular strips, which ended up as parallelograms once I had trimmed them to fit.
The problem as I see it is that there is a compound curve, (Bonnet curves in more than one direction at the same time) as you get near the grille. With a straight strip you get a wrinkle as you try to form the vinyl around this curve.
Are dealer stripes "pre-shaped" to account for this, ie have they got a slight curve in the stripe which ends up looking straight when applied?
Or am I just doing something wrong when applying the eBay stripes?
Anyone know how much for a set of stripes from a dealer or otherwise in Cork/Limerick/Kerry areas of Ireland?
Thanks in advance...
Old Dec 3rd, 2009, 03:50 PM
CrazyPhil's Avatar
United Kingdom Male View CrazyPhil's Pepper White & Black 1st Gen MINI Cooper S Profile View CrazyPhil's Classified Ads
Bonnet stripes are shaped to allow for the 'curve' of the bonnet line.
For first gen ONE/COOPER are different to S.
For 2nd gen ONE/COOPER have a straight shape and length - DIESEL is slightly longer and S is even longer, thinner and shaped.
So not all MINI bonnet stripes are the same.
We produce our own, on sale from £8 a pair in our Christmas sale !!
We fit them too
thing to remember is how long you want them to last - some suppliers and (ebayers) will use a chep end of the vinyl market and last 2-3 years.
Our vinyl cut stripes are 7 year exterior material and our printed are 7 year with a 7 year over laminate for extra protection - as we sell them all over the world !!
Phil
Old Dec 4th, 2009, 08:47 PM
Ireland
Order placed, thanks for the info.
BTW, had a look at some of your work - amazing!
Old Dec 15th, 2009, 04:43 PM
Ireland
Received (attributing length of time to international Christmas post volumes etc)
They look the business anyway, there's an obvious shape to them rather than the generic eBay rectangular strips.
Phil - one question, we're having pretty cold but fairly dry weather at the mo.
Unlikely too see much over 5 degrees C for the rest of the week - will that affect putting these on? Use a hairdryer to add some heat to help the adhesive?
Or wait for temps to rise above 10degreeC?( this will be accompanied by rain no doubt, but will be able to do this job in a shed over Christmas if I have to)
Old Dec 16th, 2009, 09:20 AM
CrazyPhil's Avatar
best results are when it is warmer so unless you can get into a garage space I would wait until at least 10 degrees - sorry but the vinyl will not stick properly if its so cold.
Dealer attitudes to aftermarket bits Roofas First Generation MINI Tuning 1 Sep 24th, 2005 07:05 PM
Best aftermarket bonnet stripes? Shep First Generation MINI Exterior 2 Apr 17th, 2005 09:58 PM
Dealer says NO to aftermarket air filter! Jones First Generation MINI Tuning 10 Aug 8th, 2003 12:16 PM
Aftermarket Racing Stripes Ex Con First Generation MINI Exterior 30 Nov 3rd, 2002 10:57 PM
US options/aftermarket questions lotuseatsvipers First Generation MINI Exterior 2 Jul 26th, 2002 11:23 AM
