Auto wipers - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 27th, 2010, 08:21 AM
Local Time: 04:12 PM
Auto wipers
Morning all,
I have automative wipers. However when i get in the car and start to drive they dont work straight away. I have to pull the stalk downwards so it quick wipes and then return it to the central position. From then on it works perfectly fine. I have to do this everytime the car is turned off and on again. Is this normal?
Also the wipers seems awefully sensative. On very fine rain they come on intermittantly which is perfect but then they change to a constant fairly quick wipe which gets annoying. Is this also normal or do i have a fault here? Anyways to adjust the sensitivity at all?
Your help is much appreciated.
Old Aug 27th, 2010, 09:41 AM
DaFlake's Avatar
MMC Member
Local Time: 11:12 AM
What year/model MINI do you have? They changed from gen to gen.
Old Aug 27th, 2010, 10:40 AM
MINICooperMurph's Avatar
aka Nick
Send a message via AIM to MINICooperMurph Send a message via MSN to MINICooperMurph
Thats not a fault thats how they work. It should say exactly that in your manual
Old Aug 27th, 2010, 01:01 PM
Im still waiting for my manual to come through.
Even the fast wipe when its barely spitting?
its a r53 face lift (2005) model
Old Aug 27th, 2010, 01:58 PM
DaFlake's Avatar
MMC Member
Is the widscreen MINI glass or has it been replaced? (look at the logo on the windscreen and you should see MINI wings). If not let us know what kind of glass it is.
The on/off operation is correct. They will automatically shut off when you turn the car off and not come back on. This is a safety feature (protection from ice or a carwash). To turn the auto on, just move the stalk to the off position (all the way down) and the back up one notch for the auto.
The fast when it is barley raining is a different matter. I would like to know if the windscreen has been replaced as the sensor (black box in front of the rearview mirror) could be bad or be having issues. I had my screen replaced and the sensor was horrible so I had them do it again. Sadly the sensor is mounted at the factory and can't be replaced without replacing the window.
Old Aug 27th, 2010, 03:01 PM
Many thanks for the reply. the black box cover did feel loose, so perhaps it has been altered in some way. Its very perculiar. It will work on a intermittent wipe for very soft rain as it should then turn into a more regular wipe when there is clearly no need. If i reset the wiper it will go back to the intermittent wipe for a while amd then back to the annoying regular. With heavy rain the wipers seem fine.
Ill check the windscreen and report back - just checked and it has the officially mini logo. I also noticed where the sensor is and im thinking the wipers are not cleaning the rain properly from that area which may be causing the problems. I will investigate further.
Old Aug 27th, 2010, 05:48 PM
Local Time: 03:12 PM
auto wipers
I had these on a pug 307 and they acted just like you describe yours.I avoid them now because they are just a pain in the a**e!
Old Aug 27th, 2010, 06:14 PM
DaFlake's Avatar
MMC Member
Mine work great, in fact, I never use the regular settings. If the sensor is damaged (he stated it was loose) then that would be the problem. The only time I had a problem is when I had the windscreen replaced and the sensor in the new windscreen was bad. Once it was replaced again (next day) it went back to working normally.
Sorry that you hate them but your comment doesn't help the OP.
Old Aug 27th, 2010, 08:10 PM
SteveM3's Avatar
I only got mine as they were part of the Visibility package but now I have them I wouldn't be without them. They wipe at just the right speed under all weathers/conditions. The only problem is very minor. If you set them at night in a bright city and drive into the dark you have to reset them. Or is it if you set them in the dark and drive into a bright city? It's one or the other.
Old Aug 27th, 2010, 10:46 PM
DaFlake's Avatar
MMC Member
I don't have that problem. Hmmm...
Old Aug 31st, 2010, 07:30 AM
Only the casing was alittle loose.
This morning they where wiping even though there was no rain!!!
Going to see if i can have them replaced under warranty methinks although its through a dealer and not a main mini dealer.
Old Aug 31st, 2010, 11:50 PM
DaFlake's Avatar
MMC Member
MINI glass?
Old Sep 1st, 2010, 09:55 AM
MINI glass?
the glass is mini genuine
Old Sep 1st, 2010, 12:05 PM
DaFlake's Avatar
MMC Member
Then it sound like the sensor has gone bad. Sadly, the only way to fix this is to replace the glass. If you just got the car I would go back and complain about it and see if there is something they will do for you.
how effective are the auto-dim mirror and auto-wipers?? mmalc Second Generation Interior & Ice 14 Apr 29th, 2009 03:01 PM
My auto wipers arn't auto minEman First Generation Interior & Ice 9 Oct 7th, 2004 03:18 PM
Auto wipers & auto dimming rear-view mirror? BlackBear First Generation MINI Exterior 26 Apr 22nd, 2004 01:24 AM
autoglass replacing a heated/auto wipers/auto dimming mirror windscreen?? ashton First Generation Faults & Fixes 4 Feb 19th, 2004 12:46 PM
Auto-wipers, auto-dim mirror not included in cold weather combo TheFU General Discussion 3 Jan 29th, 2003 08:02 PM
