Scraper Seal replacement - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 25th, 2010, 02:25 PM
Local Time: 03:12 PM
United Kingdom Female
I am getting awful streaking down my window (particularly after I have washed it and the window is wound up and down) and turns out it is the scraper seals that need replacing. As it is not covered by warranty I have been quoted £185 to have them all replaced both sides and I was just wondering whether replacing them does actually solve the problem (can only seem to find one thread relating to this). It's just that it is quite a bit of money to shell out if it isn't going to last long.
Thanks.
Old Dec 5th, 2010, 01:53 PM
Local Time: 04:12 PM
Dark Silver
Thanks.
I have the same problem , I have to lower and raise my drivers window twice a day at work for the car park entry barrier .
How much are the scrapper seals ££ and how much for the labour £££
Might leave mine until the better weather and have a look at doing it then!
Old Dec 5th, 2010, 03:04 PM
TonyFoy's Avatar
United Kingdom Male View TonyFoy's Dark Silver & Black 1st Gen MINI Cooper S Profile
Replacing the scapers does fix the problem which is caused by contamination of the seals by cleaning products according to MINI and is a known issue.
Mine got replaced under warranty 3 years ago and haven't had issue since. (R53 S)
The Following 2 Users Say Thank You to TonyFoy For This Useful Post:
Tags: , ,
Jet Seal 109 Fabinou Maintenance & MINI Care 4 May 15th, 2010 05:33 PM
engine oil cap seal? oscarricher Second Generation Faults & Fixes 0 Jul 13th, 2008 09:27 AM
BMW Seal & Protect bobc2671 First Generation MINI Exterior 0 May 22nd, 2007 07:09 PM
Silver Seal? Ragamuffin Maintenance & MINI Care 2 Feb 25th, 2006 04:05 PM
Replacement rubber window seal ? DCM First Generation MINI Cooper S 1 Jun 5th, 2005 11:22 PM
