Parking Sensor Fault - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 7th, 2012, 10:48 AM
Local Time: 05:13 PM
Post Parking Sensor Fault
Hi,
I have a 2005 R53 which has rear parking sensors, my problem is that when I select reverse gear occasionally there will be a solid and constant "Beep" as soon as I put it into gear, when this happens the sensors dont work at all and the beep stays on and constant regardless of how near I am to an object. I have a friend who works as a mechanic and he ran an ecu can when the problem happens but no fault codes came back. Has anyone has a similar problem as its highly annoying?
Old Jan 7th, 2012, 04:32 PM
tnoy66's Avatar
POP..POPPOP..POP
Online
Local Time: 06:13 PM
England Male View tnoy66's Pepper White & Black 1st Gen MINI Cooper S Profile View tnoy66's Classified Ads
You've got a faulty sensor.
Simple way to check and change http://www.mini2.com/forum/first-gen...placement.html
Parking Sensor replacement javars First Generation MINI Exterior 6 Dec 19th, 2011 12:41 PM
Parking Sensor & Visual Boost konel General Discussion 2 Aug 20th, 2011 06:51 AM
Parking Sensor problem Geoff & Gill First Generation MINI Convertible 6 May 1st, 2009 01:02 PM
PDC, Parking Sensor problem Danno1975 Second Generation MINI Exterior 5 Mar 27th, 2009 02:17 PM
Parking Sensor (PDC) Problem sportdan First Generation Faults & Fixes 4 Jan 19th, 2009 01:32 PM
