Fitting front LED strip lights? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 31st, 2012, 03:43 PM
harvey94's Avatar
Local Time: 06:14 PM
Male
Hi,
My partner has told me that she seen a mini the same as ours so mini one first gen! with white LED strip lights either inside or on the front lights which were on with the side lights.
My question is i have seen these on ebay but are they simple to fit? do they fit in the inside of the glass lens? also where to run the wire to?
sorry for the questions
Old Jan 31st, 2012, 04:52 PM
mab01uk's Avatar
Try link below, then phone/email and ask for Mike and he will be able to send you a led light kit especially to fit your Mini One:
NewMINIStuff.com
Old Jan 31st, 2012, 05:35 PM
harvey94's Avatar
Male
Thanks for the help but i can't see on that site what i am looking for, i will provide a link if it helps and any help would be great!
AUDI R8 DLR XENON LED LIGHTS BMW MINI COOPER E39 E60 | eBay
Old Jan 31st, 2012, 07:15 PM
RVW's Avatar
RVW
003 On a Mission
Online
United Kingdom Male View RVW's Hot Chocolate & Silver 2nd Gen MINI Cooper Diesel Clubman Profile View RVW's Classified Ads
Old Feb 1st, 2012, 09:16 AM
harvey94's Avatar
Male
Hi,
Yeah i seen this, i take it this is a complete replacement but it really looks nice! i have given mike an email regarding these!
Thanks guys!
Old Feb 13th, 2012, 11:16 AM
harvey94's Avatar
Male
Big thanks to mab01uk
NewMINIStuff.com
Hey,
Just to say a big thanks to mab01uk for the link! just off the phone to these guys and my new headlights as pictured above should arrive tomorrow!!
Hope its easy to wire the LED part to the side lights!
is it wrong i love my mini more than my girlfriend?
Old Feb 13th, 2012, 12:49 PM
harvey94's Avatar
Male
Hey,
Just a quick question i forgot to ask! it says that the new lights don't come with electronic leveling , does this mean you have to manually set them? is this easy?
Old Feb 13th, 2012, 06:17 PM
mab01uk's Avatar
The standard manual levelling feature is 'supposed' to be used dependant on how loaded up with passengers and luggage you are, to prevent other road users from getting dazzled if the front has raised up. There is a small thumbwheel on the right below the dash to set them usually 3 positions although hardly anyone (including myself) ever remembers to re-set them according to number of passengers, etc.
You may sometimes see or hear the headlights motors moving them on start-up from the low parked position up to the thumbwheel switch setting position. However many early Mini's seem to have one or both motors stuck or failed in the down position giving very poor headlights! Often the best way to get around the problem without buying new headlights/motors is to disable the system and then get the headlights set at an MOT testers or a Garage with the right beam setting equipment and providing you don't load up the car to the maximum you shouldn't dazzle anyone. The annual MOT checks the beams are not too high to cause dazzle and set them via the small screw adjusters behind the lamps if necessary. If they are too low I don't think they have to do anything!
I assume this is what the NewMinistuff headlights require to be done and will pass MOT, etc but maybe ask Mike for further advice, he is normally very helpful as well as being a keen and knowledgeable Mini enthusiast.
The more powerful HID/Xenon type of headlights available are however a different case and to pass MOT have to have a much more complex automatic self-levelling system fitted with no manual switch settings possible for the driver and a powerful washer jet system for cleaning them.
Old Feb 13th, 2012, 06:37 PM
harvey94's Avatar
Male
Once again i must thank mab01uk for taking the time to help me, i am actually due to go for an mot in the next 2 weeks so i will double check, i did ask the gentleman at new mini stuff if these lights would pass an mot and he said yes so i see no reason to be concerned and i am sure he would have told me if anything was required, it was just incase i had to maybe swap a part over to the new headlights, oh and you are correct, i have never ever used that dial on any of the cars i have owned! and didn't even realise it was for load purposes! well we learn something new everyday!
Old Feb 16th, 2012, 07:34 AM
harvey94's Avatar
Male
Here we go , all fitted and looking amazing!! Thanks to mab01uk for the link and thanks to the guys at new mini stuff for an excellent service!!
Old Feb 28th, 2012, 04:10 AM
Local Time: 01:14 PM
can the Halo be disconnected while keeping the other LED strip ?
Canon 5D - 40D • Tamron 17-50 f/2.8, 28-75 f/2.8, 70-200 f/2.8, 90mm 2.8
Adobe Master Collection CS5 - Lightroom 3
Old Mar 8th, 2012, 01:00 PM
harvey94's Avatar
Male
Hey guys,
Just before i make an ass of myself, will this front grille fit my car above
BMW Mini R50/R52/R53 (2001-2006) Hatchback ONE Front Grill | eBay
Old Mar 8th, 2012, 01:12 PM
harvey94's Avatar
Male
Sorry friend, i didn't realise you asked me a question! Yeah thats no problem , they come with separate wiring, so you could run your DRL's off the ignition if you wanted to, or even not have the halo come on at all, its up to you how you wire them......
Help with my Grille above please guys!
Old Mar 8th, 2012, 01:59 PM
harvey94's Avatar
Male
Ok, i am now totally lost! i now have seen this.....
BMW MINI R50 R53 ONE COOPER COOPER S CHROME BONNET GRILL NEW GENUINE 2000 - 2006 | eBay
Both say they will fit my car! HELP!!
  #15 (permalink)
Old Mar 8th, 2012, 06:51 PM
mab01uk's Avatar
Hey guys,
This picture is actually for a Mk2/Gen2 2007 onwards R56 Mini and will not fit. Maybe they are using a library picture?
Pic of R56 Mini for ref, scroll down:
MINI Cooper Forum - MINI2 Mini Cooper Forums - FAQ & DIY: General MINI FAQs and Advice
Item 2:
RealOEM.com BMW R56 Cooper Mounting parts, bumper front (to 08/10)
led strip daytime running lights? maybe how to install too? tommytse22 First Generation MINI Exterior 9 Mar 30th, 2012 04:14 AM
How to change front fog lights/auxilary lights? anzzyde Second Generation MINI Exterior 5 Oct 5th, 2009 08:44 PM
Rubber strip under front bumper... Mini Bill Second Generation Faults & Fixes 1 Nov 21st, 2007 09:12 PM
Front Driving Lights inplace of Fog lights brett First Generation MINI Exterior 29 May 8th, 2004 10:07 PM
Bonnet Strip Install Question. ( White signal lights too) zogbogbean First Generation MINI Exterior 3 Jun 18th, 2002 10:52 PM
