Mini one front bonnet grille - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 6th, 2012, 10:44 AM
harvey94's Avatar
Local Time: 06:14 PM
Male
Hey guys,
Just a quick question about the front bonnet grille on our mini 1
Basically at the front there is a chrome eyebrow i think you call it? with 3 black grilles under it, now i want to change these to chrome grilles and would like to know if these are 2 seperate parts?
I have contaced a guy on ebay selling an original front chrome grille but it only has the 3 grille bars no eyebrow? i contacted him to ask if these were indeed seperate parts but he said no!!?? which made no sense!
I can't check our car as the misses is away in it with work and didn't want to miss out as its a good price!
Old Feb 6th, 2012, 01:11 PM
Yes, they're separate parts.
The three chrome grilles will be one part together.
The top trim that goes on the bonnet is another part, and you'll also need the bottom trim that goes on the front bumper underneath the three bars.
But as you already have a chrome surround, you'll should be able to reuse these two trims and just replace the middle insert. Hope that makes sense.
Old Feb 6th, 2012, 01:33 PM
harvey94's Avatar
Male
Makes perfect sense! Thank you for taking the time to reply.
Old Feb 7th, 2012, 08:48 AM
No worries, good luck with your project. I replaced my one grille with a black honeycombe grille and black trim surround, it's completely transformed the car.
Old Feb 7th, 2012, 10:05 AM
harvey94's Avatar
Male
Hi,
Hmmm? you have got me thinking now! that sounds good, i was having a look at the front late last night and thought that maybe the chrome would be to much and look sort of cheap! Will have a look at this honeycombe grille before i make my mind up
Old Feb 7th, 2012, 10:14 AM
harvey94's Avatar
Male
Don't think the honeycombe grille is available for our mini as its a 2002 , oh well back to the drawing board, still really not sure on the chrome1
Old Feb 7th, 2012, 11:43 AM
mab01uk's Avatar
This is what you need........the black aero grille, needs a few mods to fit the lower part to the standard Mini bumper:
http://www.motoringfile.com/howto/MI...ll_install.pdf
Aero Grille Installation Instructions - Forums
I have the full chrome grille and it looks fine!
Old Feb 7th, 2012, 11:50 AM
harvey94's Avatar
Male
Many thanks for that Mab01uk, can I ask if you bought the chrome grille in one piece? I found the 3 bar front chrome fitting for our mini but the chrome eyebrow piece I have at the top and the bottom as a black strip below the top and above the bottom if you know what I mean, so basically I would have the chrome grille, the chrome eyebrow top and bottom but a black strip between both, would I need to replace it all?
Old Feb 7th, 2012, 12:50 PM
mab01uk's Avatar
The black strip (usually on a R50 Mini One) is stuck to the lower grille 'bar' of the bumper and can be carefully levered off and unstuck, then replaced with a chrome strip (as usually fitted to R50 Cooper).
See Item 8 in diagram below, (black or chrome) and Item 7 is the adhesive tape:
RealOEM.com BMW R50 Cooper Trim panel, bumper, front
Item 6 is the lower chrome eyebrow, also stuck on + clips.
The upper bonnet grille parts are here:
RealOEM.com BMW R50 Cooper Grille, hood, Mini/Cooper
Early upper and lower grille eyebrows are chrome 'fluted' with ridges, later facelift eyebrows are smooth which look better and are interchangeable.
Tip: When removing the plastic nuts for black grille from behind the bonnet lay a blanket over the engine or you will loose some when you drop them!
The nuts also need gentle levering with a flat screwdriver as you undo them to help them off the grille plastic studs, not easy while working upside down!
Old Feb 7th, 2012, 01:54 PM
harvey94's Avatar
Male
Fantastic! Many thanks
Old Feb 7th, 2012, 03:43 PM
pete
Scotland Male View pete3055's Astro Black & Body Color 2nd Gen MINI Cooper S Profile View pete3055's Classified Ads
I have 2 chrome surrounds from a 07 plate Cooper s . The top one fits on to the bonnet and the other one just above the bumper . They are in good nick and you are welcome to have them free of charge if they are of any use to you .
Old Feb 7th, 2012, 07:36 PM
harvey94's Avatar
Male
hi,
That would be superb and obviously i would pay postage, i would just need to check from the likes of mab01uk if this is compatible with my mini as i don't want to take what i can't use.
Many Many thanks for the offer!
Old Feb 7th, 2012, 07:48 PM
Caveman's Avatar
Local Time: 07:14 PM
I have 2 chrome surrounds from a 07 plate Cooper s . The top one fits on to the bonnet and the other one just above the bumper.
Assuming the parts are from a 2nd Gen MINI, they won't fit.
Old Feb 7th, 2012, 07:58 PM
harvey94's Avatar
Male
Many thanks Caveman, and a big thanks to pete3055 for the offer! series mate, many thanks anyway!
  #15 (permalink)
Old Feb 20th, 2012, 02:19 PM
United Kingdom View sct73's Classified Ads
Ive got a Gen1 and am looking to swap to a black grille. Have a look at mine and let me know if thats the kind of thing you are after, we could just do a straight swap Where are you located?
Bonnet Grille Help Please froomemini General Discussion 1 Dec 22nd, 2010 05:36 PM
Black Front Grille Mini Cooper S mildy First Generation MINI Exterior 12 May 5th, 2009 11:48 AM
easy way to take off stock bonnet grille? ChilliSteve First Generation MINI Exterior 4 May 25th, 2004 08:28 PM
Bonnet Grille Fixings Geordie First Generation MINI Exterior 2 Mar 21st, 2004 01:55 PM
Cooper S front bonnet grille on Cooper eugeneloke First Generation MINI Exterior 5 Mar 9th, 2004 01:31 PM
