How to tell xenon - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 22nd, 2012, 06:08 PM
Local Time: 09:48 AM
How to tell xenon
I have an 05 facelift cooper but how can I tell if I have xenon headlights?
Old Mar 22nd, 2012, 07:26 PM
harvey94's Avatar
Local Time: 08:48 AM
Male
Hey,
Switch them on, its obvious, you will have pure white light and not yellow, also does your headlights have washer jets?
I love my Mini more than my wife
Old Mar 23rd, 2012, 02:24 PM
I don't have xenons Can I fit them aftermarket? Or do I need genuine mini one's? I've fitted canbus LED side lights and now my headlights look pants!!
Old Mar 23rd, 2012, 03:24 PM
harvey94's Avatar
Male
Hi,
I wouldn't advise fitting xenons now, as with new regulations if not done proper you will fail your MOT, and to do it correct will be very expensive, you can get good white looking bulbs , there will still be a difference from the white of the LED but looks 60% better than standard lamps that give that bright yellow.
Old Mar 23rd, 2012, 04:37 PM
Its a H7 bulb the dipped aren't they? :/
Old Mar 23rd, 2012, 04:47 PM
Railgun's Avatar
Send a message via ICQ to Railgun Send a message via AIM to Railgun Send a message via MSN to Railgun Send a message via Yahoo to Railgun Send a message via Skype™ to Railgun
No, you need a projector housing as a reflector that's used with halogen bulbs doesn't provide any cutoff needed for a xenon bulb. If you simply replace the lamp, you'll just spew light all over the place. While it will be brighter, you'll just tick people off by blinding them.
And since it was mentioned, I'll just keep going...
You have two types, your run of the mill low-beam setup, where a halogen lamp is used for your brights, or bi-xenon, where the same lamp is used for both low and hi. Hi-beam is accomplished by either a flap that flips out of the way, or the whole bulb shifts down. If you retrofit, as mentioned, it's not the cheapest option, but do not, under any circumstances, simply replace the a bulb with a xenon bulb within the same halogen housing.
Upgrading from regular xenon to facelift xenon headlights? AlanJCW First Generation MINI Exterior 1 Apr 14th, 2010 12:19 AM
Xenon dazzpowder Second Generation MINI Exterior 1 Feb 12th, 2007 10:11 PM
Dim Xenon Carolynn First Generation MINI Convertible 3 Sep 27th, 2004 09:59 AM
To Xenon Or Not To Xenon, that is the question... ohmab First Generation MINI Exterior 26 Jul 20th, 2004 09:47 AM
Xenon WissCooperS General Discussion 10 May 27th, 2003 03:36 AM
