Cooper s fuel cap on my mini one - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 28th, 2012, 06:57 PM
harvey94's Avatar
Local Time: 07:58 AM
Male
Hey,
I know there are threads on guides for this but I just wanted to ask how simple this is to do?
I have fitted my own spoiler , lights, spotslights and so on so am not afraid to give things a try.
I only have ramps and it seems you need to jack the car up and also add additional support?
Not worried about the painting part as I am just going to spray the surround black and keep the cap chrome.
I noticed some people say they do this without actually removing the wheel? Is this even possible?
I love my Mini more than my wife
Old May 28th, 2012, 07:09 PM
olly-w's Avatar
Local Time: 08:58 AM
United Kingdom Male View olly-w's Classified Ads
Hey mate, let me know how it goes as I'm considering the same mod! Try to take lots of photos through the installation if you remember, I'm sure I'm not the only one who would appreciate photos! Good luck on making your fine motor even finer!
Old May 29th, 2012, 11:49 AM
mab01uk's Avatar
It maybe possible to fit the cap without removing the wheel but is certainly much easier to take the wheel off and support the car with a small axle stand just incase the jack drops. You don't really need ramps as you need the suspension/wheel to drop down for best access.
Guides here:
Fitting: Cooper S Fuel Cap / Side Skirts - Forums
I don't think you will find this too difficult if you remove the wheel, it is a bit fiddly and takes a bit of care/thought to protect the paintwork......before doing something on this job you need to think what will happen if a tool slips and so take care to protect the body panel from any accidental scratches. Use some masking tape and soft rags to avoid metal to metal contact with any tools used!
Old May 29th, 2012, 01:52 PM
I did this mod on my 2004 Cooper.
One of the best mods i've done!
Not difficult, just time consuming.
Take your time is the one piece of advice i would give.
It's easy to rush and damage/scratch something.
Old May 29th, 2012, 06:02 PM
harvey94's Avatar
Male
All done!!
Well thats the new fuel cap all fitted , i will run through my process as best as i can.....
First off i painted the new fuel cap cover, i decided to go with black as black and silver look good together and also i fitted a black spoiler so all blends in nice!. I used plasti-kote and gave it 4 coats as this stuff dries in 5 min! But gave the last coat a few hours before fitting
I then removed the original fuel cap cover by simply twisting it , i then used electrical tape to protect the cars paint work as i prefer this to masking tape for small areas as its more dense, as you will see i have not used tape around the whole area as the clips are only in 3 places so there is no need, here is a picture of the clips location...
Now a picture after i protected the area...
I now jacked up the car and braced both front wheels so the car could not roll forward on me , i removed the wheel and started to remove the inner fender panel , which is held in by 2 plastic nuts, these are simple to get to if you take the time to remove the actually wheel, i used a pair of mole grips to remove these, then there are about 4 or 5 plastic scrivets to remove, these are obvious to see, you may have to hold the back part as the screw may just turn and not remove, you will see from the pic i actually removed my arch trim as i just found it easier but this is not necessary
with the fender removed you will now see the fuel hose exposed, there are 2 nuts holding this in place, one facing you and the other at the top of the hose neck, i removed these so i could maneuvre the fuel filler hose...
At this point i actually found it easier to cut and remove the rubber around the fuel nozzle so i could maneuvre it , i found it easier to prise up the original cover with a flat blunt knife and then insert a screwdriver to lift the clips, i wrapped both my blunt knife and srewdriver in tape so i would not damage or scratch the paint! i then removed the old part. You will see from this picture that on the left one of the metal clips as bent out , i simply pushed this back, it bent when removing the old unit, it was not clipped in , it must just have been the way i removed the old one.
Ok so now i fitted the new part , this is simple to fit and just clips into place, make sure you line up the lock actuator so it can freely open and close, i have heard people saying this fell into the car and took them ages to fish it out, i don't know if its different on gen 1 but i don't see how this could happen as its not part of anything you remove! you don't touch the lock mech at all. Remember to Take the old fuel twist cap off the old unit by simply pulling it, this is the part that just hangs when filling your car with fuel, held on by rubber, attach this by simply pushing it into the new part with a small screwdriver....
Now its time to fit the newly painted cover , this again simply just clips into place , it just fits over the newly fitted part and clips in....
Now take the new chrome cover and screw this into place with the supplied hex screw...
Well thats it all done! A job worth doing in my opinion
The Following 2 Users Say Thank You to harvey94 For This Useful Post:
Old May 29th, 2012, 11:18 PM
mab01uk's Avatar
Looks good and a great write-up that will help others!
Old May 30th, 2012, 06:53 AM
Nice one harvey94, that will help many people!
Old Jun 20th, 2012, 10:01 PM
Local Time: 02:58 AM
Nice job!
Mini Clubman Cooper D - fuel pump DeborahM MINI Cooper Diesel 9 May 22nd, 2012 08:12 AM
Mini Cooper 2004 Fuel? & Jerking kirsty2010 First Generation MINI Cooper 1 Feb 6th, 2012 09:48 AM
Mini Cooper S Fuel Cap? R56? daz1761 First Generation MINI Exterior 2 Jun 12th, 2011 09:33 PM
Mini Cooper S Fuel Cap? daz1761 First Generation MINI Exterior 10 Jun 7th, 2011 07:37 PM
Fuel Consumption On A Mini Cooper LouieCoop First Generation MINI Tuning 12 Jan 31st, 2007 08:04 PM
