weather strip - MINI Cooper Forum
First Generation MINI Exterior
post #1 of 1 (permalink) Old Jan 6th, 2014, 10:50 PM Thread Starter
Local Time: 09:04 PM
weather strip
On my 2006 mini the weather strip around the roof is destroyed.
Is this a common issue?
I've asked a few dealers about replacing it and have been informed that the strip is all one piece (so there are three of these thicker weather strips: right, left, and rear). The expensive part is the glue sold from MINI. Does anyone have any knowledge on how particular this glue needs to be? Do I need to buy the MINI glue or would any similar product work fine? I'm assuming its an issue of reacting with the rubber in the strip, but how big of a deal is it?
Also, the strip has had a chunk missing (the curved piece that tops the vertical member on the side of the windshield) so the roof has gotten wet a few times. Any insight into what it would take to make sure there is no mold inside the roof padding?
Thanks a lot for the help and comments
rafmudaf is offline
Tags: ,
Problem starting in the cold weather Misty2013 MINI Clubman 1 Dec 31st, 2013 08:22 PM
Chrome trim strip Earnest Lee Second Generation MINI Exterior 0 Dec 20th, 2013 05:32 PM
OEM Roof Rack Removal - Weather Stripping bretonmbutler Second Generation MINI Exterior 2 Dec 18th, 2013 12:27 PM
Led Break Strip iRoo Maintenance & MINI Care 3 Feb 10th, 2013 04:05 AM
Central locking/ car starting problem in cold/ wet weather C & C mini First Generation Faults & Fixes 3 Nov 4th, 2012 04:11 PM
