Replacing Front N/S Wing (A Panel) - MINI Cooper Forum
First Generation MINI Exterior
post #1 of 2 (permalink) Old Jan 7th, 2014, 02:19 PM Thread Starter
Local Time: 02:28 AM
Hello,
New to the forum, looking for help with my girlfriends Mini. (2002 Mini Cooper)
Looking for info on replacing the Front Wing or A Panel (Classic Mini Owner)
Is it bolts or welded? Easy or hard job to do?
If it's bolts, where are they located etc please
Thanks,
Tom
tom1234177 is offline
post #2 of 2 (permalink) Old Mar 3rd, 2014, 09:16 PM
It's not too bad, all screws and nuts. The biggest pain is a torx screw on the bottom of the panel which won't want to move. Once you've removed the indicator you'll find another torx screw behind it and a 10mm nut inside towards the door. There's a couple of screws on the top which are visible with the bonnet open and a screw inside the wheel arch, you'll have to remove the arch liner to get to that one. From memory i think that's it.
Marcos999 is offline
Tags: , ,
Replacing the front bumper outer plastic trim bkeane2414 First Generation Faults & Fixes 2 Mar 22nd, 2013 04:35 AM
