Wipac Driving Lamps HELP! - MINI Cooper Forum
First Generation MINI Exterior
post #1 of 2 (permalink) Old Jan 20th, 2014, 08:22 PM Thread Starter
Local Time: 09:36 PM
Question Wipac Driving Lamps HELP!
Hi I have a 2005 Mini Cooper base and I bought a set of Wipac's Driving Lamps and there are literally no instructions with it. All that came in the packaging were the lamps with small wires coming from the bottom. Nothing else, no mounting hardware or anything. Anyone have a website or advice for me? The box says easy installation.... Doesnt seem easy to me.
crossdrew82 is offline
post #2 of 2 (permalink) Old Jul 11th, 2014, 12:50 PM
Local Time: 05:36 PM
You can get the mounting bracket from mini madness (stronger then stock type) drill 3 holes for each bracket and use steel pop rivets. Wiring is the headache if you car has daytime running lights. The reason I'd it send lower voltage to your driving light relay if dl switch is left on. This will cause relay to switch on and off rapidly and will burn it out. The dealer can turn off the drl for as charge of one hour labor.( rip off) you could bypass using the high beam circuit but this would be a pita to have to reach and switch light off every time car approaches. Now to answer how to wire: one wire from light goes to a ground the other goes to a positive source for power. I recommend using a fused relay to protect your wiring.
Adaptec2001 is offline
Crazy temperature gauge, dash lights, driving lights, window behaviours... canada911 First Generation Faults & Fixes 16 Mar 18th, 2013 02:37 AM
Mini 07+ R55 R56 R57 Chrome Spot Lights Driving Lamps Full Kit For BMW Mini UtilityGuy Second Generation MINI Exterior 1 Jan 17th, 2013 02:59 PM
Dog Driving a MINI Countryman..... mab01uk MINI in the Media 3 Dec 8th, 2012 10:13 PM
