roof decals how much? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 11th, 2003, 12:59 AM
Silvercooper's Avatar
Local Time: 01:25 PM
Canada Male
I saw a DS/W MINI like mine a few days ago with a chekered roof and I liked it a lot!
I'm thinking of buying the kit from Idle Gear and do it myself but can somebody tell me how much do dealers charge to retrofit a chekered roof?
Thanks for your responses
Old Apr 11th, 2003, 01:17 AM
Hat's Avatar
Hat
ITS RAINNIN' SIDEWAYS
Local Time: 06:25 PM
England Male View Hat's Classified Ads
dealers in the UK charge around £100. A roof decal is always 'retro fit' as the factory doesn't fit it, the dealer does. I just ordered the check roof kit from Idle Gear & it's £39 + shipping.
Old Apr 11th, 2003, 01:19 AM
monsta's Avatar
MINI2 Global Moderator
United Kingdom View monsta's Chili Red & White 1st Gen MINI Cooper Profile
Yeah the Idlegear large check one (i.e. mine) is an exact replica of the BMW version..
And it's half the price!
the MINI has gone...
Old Apr 11th, 2003, 02:41 AM
Local Time: 09:25 AM
I was quoted US$165 for installation only. So I'm opting to get the idle gear one too. Much cheaper and I can do the installation myself...hopefully. And the shipping price is good considering it will be coming from the UK.
-Andrew
Old Apr 11th, 2003, 02:43 AM
Canada Male
And is the installation fairly easy?
Old Apr 11th, 2003, 03:14 AM
monsta's Avatar
Got my local graphics company to do it but it's in three sections for easy fitting
Old Apr 11th, 2003, 02:33 PM
The "EASY FIT" large cheq roof decal, is know £39 + shipping.
It is now supplied in a differant way. I have used the same methoid as when rover supplied the classic mini decal.
You get a template, and the vinyl squares.
Place the template onto the roof, hold down with masking tape.
Then peel off the squares 1 by 1, and place in the rececess of the template.
You then build up the decal, like a jigsaw.
You will get a text instructions and fitting diagrames.
This method has cut fitting time by at least half.
If you can tie your own shoe laces, you can fit this kit.
cheers Kev idlegear
ps. see u @ imm 03
It`s a mini thing, you wouldn`t understand.
Old Apr 11th, 2003, 05:55 PM
Bonjour's Avatar
der Hummermeister
United Kingdom View Bonjour's Solid Black & White 1st Gen MINI Cooper Profile
Is there a kit that can be fitted to a sunroof, or would I need to use my initiative cutting up one of the standard kits?
Old Apr 12th, 2003, 01:02 AM
The kit will fit a sun roof vehicle, but as the vinyl is soild, you won`t beable to see through the squares.
You would just fit as normal, then using a scaple blade (ask and I`ll "give you one") just slice through the squares on the sunroof, enabling you to open the roof. The decals will not stick to the rubber seals.
kev...... idlegear
ps. see u @ imm 03
Old Apr 12th, 2003, 10:41 AM
Local Time: 12:25 PM
If you are looking for a perforated sunroof version we have that. Choose any two colors for your checks and pick between the traditional "Flat" version or our 3D version. This will work on any color roof also. matt@cooperflags.com
Old Apr 12th, 2003, 10:56 AM
wdfoto's Avatar
United States View wdfoto's Dark Silver & White 1st Gen MINI Cooper S Profile
self applied roof
I did this myself for about $20.00 and lot of soap and water and about 2 hours of my time.
DS/B&W checkered, Sports, Premium, Black Leather, 17 Performance run flats
Old Apr 12th, 2003, 10:59 AM
wdfoto's Avatar
here is the pic
Here is the picture.
Name:	dsc_3346 copycopycopy.jpg
Old Apr 13th, 2003, 12:32 AM
here is an example of what the 3D checkerboard looks like -
Old Apr 13th, 2003, 01:18 AM
AussieMini's Avatar
Send a message via MSN to AussieMini
Local Time: 03:25 AM
Australia View AussieMini's Liquid Yellow & Black 1st Gen MINI Cooper S Profile
Re: self applied roof
I did the same as WDFOTO, It cost me about 50 Australian dollars ($25US) however it took me four hours. You'd be suprised how easy it is.
Just go to a vinyl cutter and have them cut you 24 squares at 230mm. You only need 20 but get four for spares just in case you stuff a couple up.
Get a spray bottle with a few drops of dishwashing liquid and fill the rest with water. Completely clean the area and carefully stick them on. Also, use a small window squeege to squeege excess water out from under the decals once you slide them into place.
Just PM me if you need more info.
PS Here's my MINI. I actually used liquid 3M yellow checks and added the triple racing stripes on the bonnet and down the back.
Name:	bb mini2.jpg
  #15 (permalink)
Old Jan 5th, 2004, 03:01 PM
mcldan10's Avatar
aka Dan
Send a message via MSN to mcldan10
Local Time: 05:25 PM
United Kingdom View mcldan10's Pure Silver & Body Color 1st Gen MINI One Profile
Ordered mine today, Black Cheq. Roof Kit hope it is as easy as tying your shoe laces
Roof decals and moon roof Nimiety First Generation Interior & Ice 7 Jun 25th, 2006 11:12 AM
Roof Decals TJS First Generation MINI Exterior 6 May 31st, 2005 09:55 AM
Roof Decals ozzel First Generation MINI Exterior 2 Sep 23rd, 2003 10:51 AM
Roof Decals REAL MINI S First Generation MINI Cooper S 0 Apr 29th, 2003 11:44 AM
