Spot Light Wiring Question (not installation) - MINI Cooper Forum
First Generation MINI Exterior
post #1 of 6 (permalink) Old Dec 30th, 2016, 06:35 PM Thread Starter
Local Time: 03:34 PM
Quoted: 2 Post(s)
Hi, does anyone know how this WIPAC wiring harness connects spot lights to the Mini?
Specifically the green connectors? Which from what I can tell are meant to connect to the spot lights? But the lights don't have a matching connection...
The whole harness is
Power > fuse > relay
Relay > Ground
Relay > wire (assume to splice into main beam)
Relay > x2 green connectors
BMW Mini R50 R53 Genuine Wipac Original Spot Light Fog Lamp Wiring Harness Loom | eBay
Thanks for any info!
ChaoticControl is offline
post #2 of 6 (permalink) Old Jan 2nd, 2017, 02:54 AM
Local Time: 01:34 AM
Quoted: 146 Post(s)
Australia Male
Garage
This should cover what you need with the exception of changing the grill.
MINI Cooper Driving Light Installation (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
or this link
http://www.totalmini.com/forum/fitti...ing_Lights.pdf
Milpol is offline
post #3 of 6 (permalink) Old Jan 3rd, 2017, 04:17 PM Thread Starter
Quoted: 2 Post(s)
Thanks for the reply, I've come across both of those links before. The loom I linked to isn't what is supplied by BMW, but a wipac version that supposedly is plug and play, but it clearly isn't. I just don't understand why there are connectors where the spot light wiring should connect, as the spot lights don't come with a matching connection.
The seller has said 'The plugs in the original harness for the loom to plug into are behind the bumper on ether side by the chassis legs apparently'
Which is even more confusing and not helpful!
post #4 of 6 (permalink) Old Jan 3rd, 2017, 05:48 PM
JohnnyC's Avatar
Quoted: 155 Post(s)
The OEM spotlights aren't plug n play either
JohnnyC is offline
post #5 of 6 (permalink) Old Jan 4th, 2017, 02:33 PM Thread Starter
Quoted: 2 Post(s)
Yeah I have no idea how that looms works, I could wire in OEM lights, and aftermarket ones just spliced into the high beam, but god knows how this one connects, just wondered if anyone had come across it before.
post #6 of 6 (permalink) Old Jan 4th, 2017, 03:40 PM
JohnnyC's Avatar
Quoted: 155 Post(s)
The 'generic wiring kit' that I bought just does the same as the OEM loom.
But it taps into the high beam near one of the headlights.
AFAIK, the OEM loom does exactly the same, except it taps in near the BCM, so it's just far more work to route the wiring to there.
JohnnyC is offline
Help - reverse light wiring Jlk General Discussion 11 Nov 8th, 2016 12:01 AM
2003 Cooper S wiring diagram - question about cooling fan. Lars First Generation Faults & Fixes 2 Nov 19th, 2015 08:40 PM
rear light question kempsuit Australia 0 Nov 26th, 2013 12:48 PM
Replacement Spot Light Glass atticus1802 Second Generation MINI Exterior 11 Oct 18th, 2012 12:50 PM
R56 Spot Light Problems mattmyself Second Generation MINI Exterior 6 Aug 17th, 2012 11:40 AM
