Fitting third brake light - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 13th, 2003, 03:31 PM
maxdude's Avatar
Local Time: 09:33 PM
England View maxdude's Classified Ads
I am trying to fit clear third brake light but have spoiler to get round. Have read that you must losen the centre nut which fixes the spoiler, however I appear to only have them at the side and not in the centre. Any help, please!!!!!!!
Old Jun 13th, 2003, 05:01 PM
MICKEY's Avatar
Local Time: 10:33 PM
United Kingdom View MICKEY's Chili Red & Black 1st Gen MINI Cooper S Profile
The description to do this in here somewhere.
For the Cooper with the Chili spoiler. If you have the centre bolt in the spoiler you must loosen it, if not then obviously you don't need to do that part.
The rest of the process is the same I think,
you need to remove the torx screws and lift out the light unit, put masking tape all around the light unit (on the car) to protect the paint work.
Next is the hard part, you need to lift up the spoiler with some force as it's glued on. your not trying to pull the spoiler off the car or break the seal, your trying to lift the spoiler up so you can wriggle the light unit out between the car and spoiler.(it does go, I’ve done it a few times now)
It's one of those job, your either going to get right first time or your going to mess about taking a number of attempts.
It's the same putting it back.
Hope this makes sense and the best of luck.
Old Jun 13th, 2003, 09:58 PM
maxdude's Avatar
thanks, I'll give it another go!!
Wierd Screwdriver needed for fitting 3rd brake light! MaTTy_P First Generation MINI Exterior 1 Oct 3rd, 2004 07:12 PM
Help fitting white third brake light StevePSB First Generation MINI Exterior 2 Sep 21st, 2003 06:03 PM
White Third Brake Light Fitting - My Experience! MINIALEX First Generation MINI Exterior 0 Jan 5th, 2003 09:48 PM
