headlight wiring identification - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 30th, 2003, 01:02 PM
Local Time: 01:28 PM
United States View wjlyerly's Solid Black & Body Color 1st Gen MINI Cooper Profile
Since my lovely new MC has big fat sun visors and my garage door opener doesn't fit, I'm installing a Flash2Pass transmitter. This gizmo splices into the high beam on your headlights and when you flash the headlights twice, ****!, the garage door opens. (Its actually a radio transmitter and has nothing to do with the flashy part, that's just how it gets powered.)
Anyway, I need to splice into the ground and high beam line on my MC. This is the standard US headlight unit (not Xenon). There are three lines going to the assembly, marked as brown, white with green stripe and yellow with green stripe. Which one's which? If I were guessing, I'd think the brown was the ground, white for normal and yellow for high beams. Unfortunately, there's no exposed metal in the connector to check with a volt meter. Anybody have real schematics?
I got a transmitter all wired up in my wife's Accord and it seems to work, but it was a pain to get to. The mini's headlight's are slightly more accessible.
tia,
jay
Old Aug 31st, 2003, 12:01 AM
Local Time: 12:28 PM
United States View moorlockx's Solid Black & White 1st Gen MINI Cooper S Profile
On the Xenon MCS the yellow w/green chaser is the high beam wire. There's a good chance it's the same so as not to get a mechanic confused when he's working on different models.
-- '03 S B/W Magnaflow; Cibie lights; Madness intake; white 17" Team Dynamics; H&R springs; Helix swaybar; custom stripes
Old Sep 1st, 2003, 07:01 PM
Confirmed. The yellow with green tracer is the high beam line with brown as ground. Presumeably, that leaves white with green tracer as the main headlamp feed.
thanks,
jay
Old Nov 19th, 2011, 09:29 AM
Local Time: 05:28 PM
Does anyone have a wiring diagram for 2002 Cooper headlight system - all internals, motor etc. to connection plug/socket with wiring loom..?? Help please in indentifying what core does what..?? Steve
Old May 12th, 2012, 03:09 PM
Check out RealOEM.com, you first need to scroll down in the list of BMWs to the listing for MINIs, then just select your model, the follow the prompts for info on your specific MINI, then select Vehicle Electrical System and you get a series of diagrams for the main harness and all the associated parts, sub-harnesses etc.
Good luck
Wheel identification please minirog Wheels, Tyres & Brakes 36 Jul 9th, 2006 02:38 PM
John Cooper Works identification ogreshooter First Generation Works 2 Mar 11th, 2006 01:09 AM
Removing Headlight Wiring Connector? Radar580 First Generation MINI Exterior 0 Apr 19th, 2005 10:13 PM
Mini Identification gusgriller General Discussion 14 Jul 15th, 2004 10:45 PM
Color Identification Plate lusomini First Generation MINI Cooper S 3 Oct 1st, 2003 06:07 PM
