1) How do you remove the Cooper (or MINI) Emblems? Are they bolt on or are the on with some type of adhesive?
2) Are the emblems metal or plastic? I would like to repaint mine (or powdercoat them if they are metal).
Thanks.
-Rob
"Hey, where am I going?"
"And why am I in this handbasket?!?"
Rob,
this has been covered before, but anyway. Get some strong thread, quite thin stuff, and gently loop it under the letters, then with a loop of it round each hand use a sawing motion to remove each letter.
ONE owners are good at this!.
Then when you've gottem all off, clean up the residue goo with some white spirit, and finally buff to an immaculate shine with Autoglym!.
No holes, no bolts, just 3M double sided tape. Letters are 'PLASTIC' so you could paint em with dome decent exterior grade paint, but its important to key a good surface, otherwise ot wont look too good in 6 months time.
Hope this helps
Hmm, I searched for "remove badge" and "remove emblem" and all I found was how to remove dealer emblems...... I DID try to search for it. Figured it had been covered before....
Anyway, thanks for the help. Sounds like it shouldn't be too bad.
Now, I just need to figure out how to remove the outside door handles.
-Rob
Actually, I am serious. Don't know why I'm getting soo much flak from you. Had a bad day?
I don't like the chrome bits on my Cooper. I've got a powdercoating kit and wanted to paint all the chrome black to match my roof. Probably not everyone's cuppa, but I think I'll like the look.
-Rob
Trust me, dont it loadsa times, just heat the badge up, to soften the glue and then after a few minutes of heat just carefull prise the badges up with your finger nails.
When completed, just give the area a quick polish and your done!
The front badge is held on with pins as far as I know! Whats invovled in a powder coating kit!?
hi, this is just my opinion, no one get the wrong idea
i wouldnt use white spirit on your mini, the laquer coating is not as thick as most cars, and doesnt take much, if you want to get the rest of the stuff off, use the hairdryer, but not too much to stress the paint. or just wash them off, it will take longer but wont damage
removing the handles is very difficult
if you need to replace them they are 12.50 each
you need to remove the inside door panel, then you have to get a very long alum key, (or driver) i dont know what size,
you need to look inside the panel with a torch, then you find the white plastic covers inside, they have two alum bolts on them, it takes a long time to get them off, when you do. remove the handles, but look at where the latch cable goes. (it took me 2 hours to find out where it goes)
when you have done your stuff, put the handle to the door and feed the wire round the back of the door electrics, then hook it to the lock mech. sounds simple (it aint) then put the bolts back on.
hope this helps, (i wouldnt take the handles off.)!!!
Sorry not a bad day, just wondered why you would want to take the handles off, thought it was "ironic" comment
Anyways its not a fun job taking off the handles and putting them back again, plus they are 'plastic', so I'm not convinced about powder coating, they are not too expensive, though. Good luck
Sorry, Goonery, I guess I wasn't clear as to why I wanted to remove them.
Given that they are available at the dealer, apparently, I may just buy the emblems and handles first and paint them black. Then, if I like the work, I can go about replacing them.
MiniOnd - The powedercoating kit is pretty neat. The way powdercoating works is, you charge the piece you want to paint by hooking it up to an outlet (included in the kit) and then hook up the gun. The paint coming out is of one charge, the metal another, so they are attracted to one another. It truely is a powder that comes out, so whatever hits the floor, you can reuse.
You then bake the piece in an oven for 10 minutes and it leaves a VERY durable finish. A buddy of mine bought the kit and I picked up a used Toaster Oven to bake the parts.
Course, since all the parts seem to be made of plastic, just painting will have to do.
-Rob
