| The paint codes are on the VIN plate under the bonnet, any decent body shop should be able to do it, the trick is to get the surfaces much smoother than they are, then apply a plastic primer before the top coat. Best way is to buy new wheelarch spats, and get them done off the car, then swap then over when you are happy with the result. The replacement arch spats are pretty cheap, and a good sprayshop will do them for around £100 with fitting extra.Car accessory shops do stock all the materials you need, so you could DIY, but you need a clean dry warm dustfree environment to get good results. |
| Body Trim removal for Colour Coding. | schapman | First Generation MINI Exterior | 28 | Dec 13th, 2004 08:35 PM |
| Roof Colour & Insurance Quote | xavier2k3 | First Generation MINI Cooper | 18 | Oct 27th, 2004 09:38 PM |
| Got a quote for colour coded arches | Cooperchris | First Generation MINI Exterior | 7 | Sep 25th, 2004 12:50 PM |
| mudflaps and body trim | cooper-boy | First Generation MINI Exterior | 0 | Mar 22nd, 2004 08:16 AM |
| Body Colour Painted Black Trim | paulmon | First Generation MINI Exterior | 14 | Dec 17th, 2002 04:57 PM |
