convert rear fog lights to run/break lights - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (3) Thread Tools Rate Thread
  3 links from elsewhere to this Post. Click to view. #1 (permalink)
Old Jan 1st, 2004, 01:00 PM
Local Time: 12:30 PM
To use the inoperative rear fog light as a running light / brake light, would you need to jump connectors 1 & 4 as well as 2 & 5, and install a duel brake light bulb in the fog light socket?
Thanks bobW
Old Jan 1st, 2004, 01:08 PM
Surfboy88's Avatar
2003 Liquid Yellow Cooper
Local Time: 09:30 AM
United-States
You just add a jumper between 1 and 4, and use the existing bulbs.
The part of the bulb that would have lit up for rear fogs will activate as additional brake lighting.
Someone at the last Mini rally I went to pulled the wiring plug out and showed us the jumper position.
I'm not sure whether she just pushed the jumper in alongside the the existing wire ends or attached it in another way.
What's the best (and most secure) way ?
:: dave ::
Old Jan 1st, 2004, 01:31 PM
Pamlico's Avatar
Dead Man's Curve? Feh.
Send a message via AIM to Pamlico
Local Time: 01:30 PM
United States Male View Pamlico's British Racing Green & Black 1st Gen MINI Cooper S Profile
As Surfboy88 mentioned, all you need to do is insert a jumper - initially I used a straightened paperclip, athough a jumper purchased at an electrical supply store might be more apprpriate.
If you're thinking of having the rear fog lamps activated, you might want to use a diode as the jumper as this will allow you to have the upper bulbs serve as both additional brake lamps and fog lamps. THis has been discussed in some detail on North American Motoring (the old Mini Cooper Online). Check here to get to one of those discussions which includes pictures of the modification.
NOTE: The earlier messges in the linked posting describe and show a modification to the rear lamp circuit boards, but go to the second page and scroll down and you'll find pictures of how the jumper (diode) can be installed between contacts 1 and 4 on the connector. This is the route I followed when I activated the rear fogs and all works well.
Good luck.
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-exterior/48004-convert-rear-fog-lights-run-break-lights.html
Posted By For Type Date
Intercambiar luces pilotos - Página 2 - Club MasMini This thread Refback Jan 29th, 2009 04:06 PM
Intercambiar luces pilotos - Página 2 - Club MasMini This thread Refback Jan 29th, 2009 03:51 PM
Intercambiar luces pilotos - Página 2 - Club MasMini This thread Refback Jan 29th, 2009 03:44 PM
No Rear Fog Lights andylee97 First Generation MINI Cooper S 24 Jan 4th, 2005 11:45 PM
Rear Fog Lights - US indimini General Discussion 14 Nov 16th, 2004 01:06 AM
Using installed Rear Fog Lights as Fog + Extra Brake Lights. Possible? averyocooper First Generation MINI Exterior 4 Mar 3rd, 2004 07:09 PM
Did you know the 7-Series has Rear Fog Lights that double as emergency brake lights? BruceK General Discussion 7 May 7th, 2003 03:30 AM
Rear Fog Lights? jbkone First Generation MINI Exterior 60 Apr 25th, 2003 12:48 PM
