main/hi-beam bulb type - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 10th, 2004, 01:18 PM
jasonfields007's Avatar
Send a message via MSN to jasonfields007
Local Time: 05:30 PM
United Kingdom Male View jasonfields007's Classified Ads
hi does anyone know what bulb type is needed for the main/hi-beam bulbs.
thanks
jason
'06' Cooper S Convertible - Astro Black, '04' Mazda RX8 231 - Black
Old Jan 10th, 2004, 01:20 PM
6X therapist
Local Time: 06:30 PM
View Goonery's Classified Ads
You mean the bulb type ? Its H3 if you are not Xenoned
Old Jan 10th, 2004, 01:26 PM
I'm Xenoned... what now?
Old Jan 10th, 2004, 01:32 PM
6X therapist
You cannot change the Xenon bulb, the main beam and dip are the same bulb with a 'defelector' device that shades the beam when on dip. When you want main beam the shade flips outta the way. Xenon lamps are designed to last the life of the car, so there is'nt an alternative.
Old Jan 10th, 2004, 05:43 PM
Paul's Avatar
MINI2 No.1
England Male
You talking about the "high beam" as in the one you use at night on country lanes? Not the "normal" high beam as in not sidelight?
Old Jan 10th, 2004, 05:48 PM
mikeythemini's Avatar
They are seperate bulbs.
The 'xenon' one is for dip beam
top part of headlamp
the main or full beam is in the lower part of the headlight (circular section)
It is a H7 bulb - I replaced my ones with Lucas 100w versions - had them a year now, much better and no problems
Old Jan 10th, 2004, 08:14 PM
Harpo's Avatar
Havin' fun...
United Kingdom Male View Harpo's Nightfire Red & White 2nd Gen MINI Cooper Diesel Profile View Harpo's Classified Ads
Quote: Originally Posted by mikeythemini
...It is a H7 bulb - I replaced my ones with Lucas 100w versions - had them a year now, much better and no problems
Mikey, I imagine 100w bulbs would be much better.
I'm running on Osram Silverstars rated at 55w - are the 100w Lucas' readily available and are there any electrical system implications by using them?
I've never been impressed by the OE, and the Silverstars don't improve matters that much either, would I be right in thinking that 100w's would nearly double brightness?
Thanks in advance for your advice.
buzzing from speakers when headlights on main beam Adam cook First Generation Interior & Ice 7 Feb 10th, 2007 04:34 PM
Spotlight with main beam robh964 First Generation MINI Exterior 10 Dec 8th, 2006 05:39 AM
Main Beam problems matada34 First Generation Faults & Fixes 3 Feb 6th, 2006 07:45 PM
Do you Wave, Flash main Beam or Ignore Pansmiker General Discussion 36 Aug 25th, 2005 02:26 PM
Dodgy main beam Mini Cruiser First Generation Faults & Fixes 11 Dec 24th, 2002 02:11 PM
