aero kit grills w/o the bumpers and side skirts i know that there are some guys running the stock standard S bumper and using the aero kits grill on it. i was wondering if anyone could help me on how the stock one comes out and the new one goes it. specified please. chris |
| The bonnet grill is real simple, just a couple of clips and nuts. The bumper grill requires taking off the bumper, and cutting the aero grill to fit. It is a real pain in the ass but looks good once you get it done. There are instructions as to how much to dremel off the grill for a good fit somewhere. I personally went thru two grills before the third one was done right. good luck, jason |
| I think this will help you: http://www.bridger.us/mini/howto/MIN...ll_install.pdf ![]() 2006 MINI Cooper with JCW Sound Kit - sold July 2009 Now driving Golf VI GT TSI 1.4 160PS |
| Hello there, I just did mine myself. Like everyone said the grill on the bonnett is simple to remove, and replace. If you wish to reuse it in the future, you'll have to be carefull not to break the plastic pieces the nuts are on. I broke the first one, but after using needlenose visegrips to hold the nut as tight as I could without crushing it, I was able to gently pull down to back the nut off the plastic dowel. sorry not sure exactly what to call those things, if you look, you'll know. The rest of the nuts came off without breaking the plastic, thus making it sellable or give awayable ![]() The lower portion is a bit more involved, but not much. I personally did not want to take the car to the dealer. Basically I removed 7 bolts total, two accessed in the outer edge of wheel well by reflector, two on top of the bumper (hex bolts) and three under lip of bumper. All are bolts Not screws (incase you get confused when you look under there). After I got them all off I simply lifted and pull the bumper toward me and let it hang there, located tabs for lower portion of the grill, lift and push them thru. I Bassically the lower part is to thick, and the tabs that held the original strip in place do not match up. I took the new piece and held it in place, marked up where the tabs should be and made them (tabs) as I dremmelled away the plastic to thin the piece out. Factory applyed glue to tabs on the original piece, I used shoegoo on the back of the after market piece. The grinding was only real drag about the whole process, but it worked. hope some of this helps motor on! |
| Thanks, I work hard on my car, compliments are nice. And you can get the grills from any dealer, just like they said. Any part can be had. Just remember, it takes some fitting so dont rush it, take your time and be paitent. cheers, jason |
| did mine also on my blk.blk. s . looks are killing. just take your time on middle grill.i used dremmeral,not the drug-the tool. 2-part epoxy &glue gun.removed bar that hinders setting grill deep enough. cut about 3/8 along entire botton edge of new grill .also do a searsch (aero grill) doug |
| w00t, I've finished the bottom grille! Took a lot of Dremel cutting, a dab of gluegun action, and a bit of matt black spraycannage behind the grille so that the unmissable EB didn't show through. Here's the end result - I'm pretty chuffed BOUGHT 2003 - SOLD 2009 - gone to Pistonheads! |
| is my old front and back bumpers and side skirts worth selling if i get an aero kit? | miniian | First Generation MINI Exterior | 3 | Jan 3rd, 2006 07:02 PM |
| Aero kit bumpers with standard S skirts | ~Marcus~ | First Generation MINI Exterior | 9 | Oct 25th, 2005 12:59 PM |
| Aero kit side skirts | yorkshire-sam | First Generation MINI Cooper S | 6 | Oct 30th, 2004 11:51 AM |
| Aero kit bumpers with Cooper S skirts ??? | dreadbones | First Generation MINI Cooper | 3 | Jul 19th, 2004 09:29 PM |
| Aero kit side grills | Cooperchris | First Generation MINI Exterior | 10 | Mar 30th, 2004 11:51 PM |
