Using installed Rear Fog Lights as Fog + Extra Brake Lights. Possible? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 3rd, 2004, 06:39 PM
averyocooper's Avatar
Local Time: 10:31 AM
(I *think* this may have been posted before but I searched with no sucess)
I just got the rear fog lights I installed activated at the dealer and wanted to see if it was possible to wire the lights to activate when I hit the brakes as well.
To be clear, I would like the lights to activate when:
1- I flip the toggle and activate the rear fogs according to the built in software restrictions (front fogs and parking lights must be on or low beams must be on)
2- I hit the brakes at any time regardless of the toggle status (rear fogs on or not)
Is there a way to do this with a little tinkering?
Thanks in advance,
averyocooper
Old Mar 3rd, 2004, 06:49 PM
mikeythemini's Avatar
Local Time: 06:31 PM
You just need 4 diodes
Old Mar 3rd, 2004, 06:53 PM
any tips or links on the project? thanks!
-a
Old Mar 3rd, 2004, 07:00 PM
NEMINI.org
Local Time: 12:31 PM
United States View NEMINI's Silk Green & Black 1st Gen MINI Cooper Profile
try a search on these forums, its been done and sicussed several times, a search for diode and/or rear fog* should probably do it.
Old Mar 3rd, 2004, 07:09 PM
I thought the instructions might be different if the fogs are activated. i guess not. thanks.
-averyocooper
http://www.mini2.com/forum/first-generation-mini-exterior/48282-rear-fog-lamps-brake-light-mini-one-diesel.html
LED Brake lights and Fog lights? EBMCS03 First Generation MINI Exterior 72 Aug 13th, 2004 03:04 PM
convert rear fog lights to run/break lights bobw First Generation MINI Exterior 2 Jan 1st, 2004 01:31 PM
Did you know the 7-Series has Rear Fog Lights that double as emergency brake lights? BruceK General Discussion 7 May 7th, 2003 03:30 AM
Brake cooling duct instead of fog lights? jmardy First Generation MINI Exterior 2 Jul 12th, 2002 12:24 PM
